Re: Pietenpol-List: Bad news - broken fuel tank fitting & warning to
Original Posted By: John Egan
RE: Pietenpol-List: Bad news - broken fuel tank fitting & warning to
With a properly prepared fuel tank surface and a properly prepared aluminumpiece you should be able to use just epoxy to stick them together. and itshould break the tank before the bond separated. Mixing glass in the resindoes you no good at all in this applicationBrian KrautEngineering Alternatives, Inc.www.engalt.com-----Original Message-----
