Pietenpol-List: Spar Butt Joint Help
RE: Pietenpol-List: Spar Butt Joint Help
Original Posted By: Jack T. Textor
Jack,Thats what I did. I didn't discover the problem until I went to slide the sparinto position. I just used a Dremmel with a router attachment to relieve the areyou are pointing to.Rick Schreiber----- Original Message -----
Re: Pietenpol-List: georgia piets anyone?
Original Posted By: Gardiner Mason
Big Piet Builders regular workday is Monday night in Carrollton. Contact me off list and I will give you directions.Barry Davis ----- Original Message -----
Pietenpol-List: Re: Dumb wing spar mistake?
To me, if the three holes are acceptable where they are supposed to be, they shouldbe acceptable where they are accidentally - since nothing actually fillsthe holes to replace the tensile properties, although fasteners could be arguedto at least provide some support under compression when called upon to do so.Once you add doublers no worries IMHO.Mike D.--------Piet-builder-who-hopes-to-be-flying-next-summerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 14 Apr 2008 14:30:48 -0400
