Original Posted By: shad bell
Pietenpol-List: Trim Control
RE: Pietenpol-List: Trim Control
John,I attached two springs to the bellcrank and fed cable through the rear seatbulkhead to a wheel in the cockpit. A quick turn on the wheel seems to beenough to hold the nose up a bit.Check out the pictures for more info.http://www.cpc-world.com/images/IMG_110 ... rWonthaggi Australiahttp://www.cpc-world.com _____
Re: Pietenpol-List: springs
This is the part number, as posted by Bill Church, for the John Deere spring in case anybody else is looking for the info.John Deere sells a spring that's a perfect match for the specs; its part number is T 143444, and it costs about $9.00. Its outer dia. is 1.5in.; full length( no load ) is 6.73" Bill C ----- Original Message -----
