Mike,I used one of them and a Stanley rip saw to make my first (and presently,only) prop.Don't leave home without one.PeterWonthaggi Australiahttp://www.cpc-world.com (with a couple of newpictures and video!) _____
RE: Pietenpol-List: Stanley Surform planers----a lifesaver when rounding
Pietenpol-List: Re: Stanley Surform planers----a lifesaver when rounding
I have a little pocket plane and will be using that after seeing how hard it isto control a router cut. Were you referring to the raspy looking fella (SurformPlane - Regular) as well? You're right. It's cheap. Also, on the topic of stabilizer construction, I am worried that if I put the stringersin on one side (to guarantee that it stays good'n flat) the slight bendat the LE will cause a warp and when I flip it, and the aggregate pull by allof those (8 on one side) stringers will be difficult to combat. But if I gluethem in as a top and bottom pair out of the jig, I won't be able to guaranteethe flatness. Ideas? Am I being a worrywort again? It is perfectly trueout of the jig so it might not be an issue to go with the second idea. Thanks--------Glenn ThomasN?????http://www.flyingwood.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 23 Jun 2008 06:25:56 -0600
We can see your lips moving, but nothing is coming out!Brian KrautEngineering Alternatives, Inc.www.engalt.com ________________________________________________________________________________Subject: Pietenpol-List: Re: Stanley Surform planers----a lifesaver when roundingedges
Those pictures you posted show exactly what I am talking about. ...and after re-readingJacks comment on doing this, I realized that I missed some info theon the first read. Between the two of you I should be in good shape tonight whenI execute.Thanks--------Glenn ThomasN?????http://www.flyingwood.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
