Original Posted By: shad bell
Re: Pietenpol-List: Aileron cable exit/pulley clearance blister
Original Posted By: "Skip Gadd"
Tom,I don't recall two sleeves being used anywhere. I pull-tested all structural cables to over 1000 lbs for pre-stretching and sleeve strength.Regards,TomOn Dec 3, 2008, at 9:44 AM, TOM STINEMETZE wrote:> >Nice one Ben -- here is the way I skinned the cat.>> >Tom Bernie> >Gloucester, Mass> Tom: Very nice looking exits! I was just wondering, though. It > seems like every photo I see of a Nicopress cable end uses a single > Nicopress sleeve. If I remember my Tony Bingeliss correctly I > believe he recommends two sleeves per fitting. Do any of you list > members want to express an opinion on this?>> Tom Stinemetze> McPherson, KS.>Thomas Bernietsbe________________________________________________________________________________
RE: Pietenpol-List: Aileron cable exit/pulley clearance blister
Others have put this question to rest, but, just for clarification, the"Swage-it" tool that ACS sells says, ".when using 1x19 cable, use 2 sleevesat each end." Most of us are using 7x19, so, reading between the lines, itappears that 1 sleeve is adequate on other types of cable.Gary BootheCool, Ca.PietenpolWW Corvair ConversionTail done, working on fuselage (endless metal parts!)(12 ribs down.) _____
Gary,You will find bending 1/8" 1x19 cable around a thimble very difficult.Regards,Tom BernieGloucester, MassOn Dec 5, 2008, at 2:48 PM, Gary Boothe wrote:> Others have put this question to rest, but, just for clarification, > the =93Swage-it=94 tool that ACS sells says, =93=85when using 1x19 cable, > use 2 sleeves at each end=85=94 Most of us are using 7x19, so, reading > between the lines, it appears that 1 sleeve is adequate on other > types of cable.>> Gary Boothe> Cool, Ca.> Pietenpol> WW Corvair Conversion> Tail done, working on fuselage (endless metal parts!)> (12 ribs down=85)
