Pietenpol-List: Modified Pietenpols
>From my experiences, the No 1 Piet had full length wings and flat ends with fulllength ailerons. My No2 Piet had 2 ft shorter wings and the aileron were shortenedone foot, and a number of times I ran out of control on a brisk crosswind landing. That means the stick was up against the max side movement. WhenI shortened my 612 wing I kept the full length ailerons, and now a 35 MPH crosswindcan be handled without running out of stick control, and it gives excellentroll rate speed when you need it. All provided one stays ahead of the airplanesgyrations on a very windy day. And as Mr. Pietenpol told me, " If your idea works try it, and it doesn't haveto be perfect".Pieti LowellRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Modified Pietenpols
Original Posted By: Jim
While we are on the subject of modified Pietenpols check this one out.http://books.google.com/books?id=6eEDAA ... -----Chris TracySacramento, CAWestCoastPiet.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 26 Dec 2008 23:33:54 +0000 (GMT)
Re: Pietenpol-List: Re: Wing Tips
http://www.zenithair.com/stolch801/desi ... tmlHalfway down- wingtips.The Horner could satisfy everyone ( OK, maybe not! ) byhaving a rounded shape and better tip performance.Clif At the risk of getting flamed here, especially since I think this is> my first post to this list, how about Hornier tips? The Hornier tip > should theoretically> increase the effective length and look neat. > Al Hays> Gore, VA>________________________________________________________________________________
Re: Pietenpol-List: Modified Pietenpols
I got one more that will give some of you ulcers and others wild ideas. This one is from the Feb. 1982 Sport Aviation. I must admit it's a good looking plane.ChrisSacramento, CAWestCoastPiet.com________________________________________________________________________________Date: Sat, 27 Dec 2008 06:01:02 +0000 (GMT)
Re: Re: Pietenpol-List: Modified Pietenpols
