Pietenpol-List: Tachometer for Corvairs
I have been looking around for a tach for a corvair engine. I don't really want to reinvent the wheel, so... What is everyone using?ThanksBarry________________________________________________________________________________
RE: Pietenpol-List: Tachometer for Corvairs
Barry,This is the one I used.Stewart Warner tacho 82636 with sender 82646. Check outhttp://www.stewartwarner.com/Catalog/2dlx1.htm ... rWonthaggi Australiahttp://www.cpc-world.com _____
Re: Pietenpol-List: Tachometer for Corvairs
Original Posted By: dog67(at)aol.com
Barry is correct. From William Wynne's website:Subj: TachometerDate: 3/4/05What was the name & type of tach that counted flywheel teeth? Tim, Manual # 6113, East Central Ohio Reply from WW: We use a Stewart Warner tach. The one we have installed in our 601 is a 0-3,500rpmunit, which has a full sweep, allowing you to clearly see a 25rpm difference. Because it works by countingflywheel teeth, it is entirely divorced from the ignition system. The Stewart Warner part no. is 82636.If you look at our 601 Web Page, you'll see the tooth counter attached to the front alternator bracket.I've used this tach in many Corvair powered airplanes over the years. I like it because it hasvery smooth operation, and it is extremely accurate when checked against our digital optical tachometer. Oscar ZunigaNon-Corvair Air Camper NX41CCSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________Subject: Re: Pietenpol-List: Tachometer for CorvairsDate: Thu, 08 Jan 2009 09:33:13 -0500
Original Posted By: Peter W Johnson
PeterDid you have to choose a certain ratio? Where does the sensor mount?Thanks Barry ----- Original Message -----
Barry,I don't think I mentioned any ratios when I ordered the sender. This picturehttp://www.cpc-world.com/new_card_images/image ... 22_JPG.jpg shows howit is mounted next to the starter motor.CheersPeterWonthaggi Australiahttp://www.cpc-world.com _____
