Pietenpol-List: first look at this
Original Posted By: "Ernie Moreno"
For a wintery afternoonhttp://www.youtube.com/watch?v=NUmIO_MG5IUwalt evansNX140DL________________________________________________________________________________
Re: Pietenpol-List: Newbie
Original Posted By: "CHRISTINE BAXTER"
hello Mark, i am located at Independence Or. I have a pietenpol Aircamper as well as the GN-1 plans.Ernie MorenoIndependence Or.----- Original Message -----
Original Posted By: "Thomas Bernie"
Tom. For what it's worth.I would think long and hard before I extended the motor mount. I believe it would make your plane very susceptable to ground looping. You might want to investigate moving your wing back to achieve a good W&B. I would suggest you may want to put that question out to the group.Just my thoughtsGene----- Original Message -----
Original Posted By:> Gene & Tammy
Gene and Tom,The GN-1 wing to cabane attach brackets go east/west not north/south likethe Piet brackets. The wing cannot be moved aft like a Piet wing can.Skip> [Original Message]
Original Posted By: "Skip Gadd"
Thanks Skip, I was unaware of that. Sorry.Gene----- Original Message -----
Re: Pietenpol-List: Model A mixture control
Original Posted By: John Smoyer
John,I'm not jumping in due to experience, only cause of various bits of knowlege from my Mentor.He locked and safety wired the mixture control on my A-65.He said that you don't have to worry about mixture till 10,000 ft or so.Don't know how high you plan on flying with the "A"Also don't know what type of fuel you'll be using.But he said that if using auto fuel, because it's so volitle, that it can start gassing off at about 6,000 ft, with a chance of vaporlock.In other words, he was more worried about the auto gas than the mixture control.walt evansNX140DL ----- Original Message -----
Re: Pietenpol-List: Stewart Systems EkoSeal
Just keep in mind that the bond of the fabric to the wood means nothing. The bond of fabric to fabric overlap is the strength.Some sew/buy fabric "bags" that they slip over the wing and shrink.walt evansNX140DL ----- Original Message -----
>> ________________________________________________________________________________Date: Sun, 1 Feb 2009 04:36:58 -0800 (PST)
Original Posted By:> "Thomas Bernie"
> Subject: Re: Pietenpol-List: Newbie>>> Tom. For what it's worth.> I would think long and hard before I extended the motor mount. I believeit > would make your plane very susceptable to ground looping. You might wantto > investigate moving your wing back to achieve a good W&B. I would suggest > you may want to put that question out to the group.> Just my thoughts> Gene>> ----- Original Message -----
> >> > >>________________________________________________________________________________Date: Sun, 1 Feb 2009 07:58:24 -0800 (PST)
Original Posted By:>> "Thomas Bernie"
>> Subject: Re: Pietenpol-List: Newbie>>> >>>> Tom. For what it's worth.>> I would think long and hard before I extended the motor mount. I believe> it>> would make your plane very susceptable to ground looping. You might want> to>> investigate moving your wing back to achieve a good W&B. I would suggest>> you may want to put that question out to the group.>> Just my thoughts>> Gene>>>> ----- Original Message -----
Original Posted By: "walt"
>> >>> >>>>>>>>>>>> -- > Checked by AVG.> 12:00 AM>> ________________________________________________________________________________
