RE: Pietenpol-List: Heel brake pedalsDate: Mon=2C 9 Feb 2009 16:04
Thanks Jack..I guess I could cut some different lenghts of 2X2 and prop them against the front ash crossmemebr till I find the right spot where I can brake and still steer.. Right now I'm thinking of 5" Azusa mechanical drums. Light weight=2C inexpensive=2C not to powerful and no leaks or bubbles. Ed G.Subject: RE: Pietenpol-List: Heel brake pedalsDate: Mon=2C 9 Feb 2009 16:04.comNot a dumb question at all. My recommendation is to mock up some pieces for your fuselage and try them out=2C sitting in the pilot=92s seat. That=92s what I did. Too hard to make recommendations since everyone=92s airplane and body are different. One word of advice that I wish I had when I installed my brake cylinders is to make sure you install them in such a way that bubbles of air will not have to travel downhill in order to bleed the brakes. My brakes are a royal bear to bleed.Jack PhillipsNX899JP
