Back when Waldo was a daily hot topic, someone said they had some "extras"they were going to sell affordably. If that ever came to pass, would thegentleman contact me because I still can't seem to find one.Thanks,Douwefinishing cockpits, hooking up instruments, getting ready to paint fuse.90% done, 90% left to go!________________________________________________________________________________
Pietenpol-List: Waldo Pepper DVD
Re: Pietenpol-List: Waldo Pepper DVD
Douwe,I have the vid If you'd like it. No charge.Kind of annoys me, I sent it to someone on this group by snail mail, and they didn't acknowledge it. Even when I emailed to see if they got it,,,no response.People stink.PS let me know if you want it, and give me a snail mail address.email me here,,,wbeevans(at)verizon.netwalt evansNX140DL----- Original Message -----
Pounce your own. Go to a sewing shop ( or your mother)and get a pounce wheel. The traditional way is to" pounce" chalk dust in a bag through the holes..If you choose a wheel with big enough spikes you canprobably spray through the holes.Since you're going DIY you might as well go all the way.Clif> >> Here's another idea for you guys that want to paint with a stencil. You > can send your graphic to a sign shop and they can run paper through their > plotter with something called a pounce wheel instead of the usual vinyl > cutting knife. >> --------> Glenn Thomas> N?????> http://www.flyingwood.com>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... ---Checked by AVG - www.avg.com18:00:00________________________________________________________________________________Subject: Re: Pietenpol-List: Waldo Pepper DVD
Pietenpol-List: Re: Making own graphics
Do you know if they make a hand type thing, like a pizza cutter style pounce wheel?If they do I imagine they would be fairly cheap, you could lay your graphicout on a table over a big piece of paper and just trace the lines with thepizza cutter pounce wheel pressing the spikes through your graphic and the paperunderneath. You're right. The sign guys do use chalk. I forgot. I'm not a sign guy.--------Glenn ThomasN?????http://www.flyingwood.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Making own graphics
Re: Pietenpol-List: Re: Making own graphics
Nevermind. I Googled it and found one instantly. This kit contains the pizzacutter pounce wheel, the chalk, and a pounce pad and a description of how it allworks. I imagine I will use this some day so might just buy one of these nowand have it to play with. Way too far from the end to even think about tormenting myself with logos.--------Glenn ThomasN?????http://www.flyingwood.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Re: Making own graphics
Original Posted By: Glenn Thomas
I was thinking a bit more high tech actually. More like a power point projectoror transparency to project the image against the Piet. Then its paint by numbers.The good part is only drawing and the projection size can be adjusted totaste and or style. No contamination of the work area by chalk or other foreignmatter. John------Original Message------
