Pietenpol-List: beanfield bird
Rick,Didn't come through on the email for me either, however if you click on the link to the post on the web-based forum (towardsthe bottom of the original email) you can see the pics there....RyanSent from my mobile deviceOn Aug 2, 2009, at 1:29 PM, Rick Holland wrote:> Didn't work that time.>> On Sun, Aug 2, 2009 at 12:11 PM, Baldeagle > wrote:> >>> Let's see if I can attach some photos->> Shade tree mechanics at work>>> Piets in a hayfield at dawn>>> Piet with a broken crankshaft in a bean field near Momence, IL>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... 671#255671>>> ==========> st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List> ==========> http://forums.matronics.com> ==========> le, List Admin.> ="_blank">http://www.matronics.com/contribution> ==========>>> -- > Rick Holland> Castle Rock, Colorado>> "Logic is a wreath of pretty flowers, that smell bad">>________________________________________________________________________________Subject: Pietenpol-List: beanfield bird
Original Posted By: shad bell
I take it the plane that ended up with a broken crank is the one with the modelA engine that also had the broken mag mount earlier? I have not been followingthe Piets progress long enough to know if that has been an issue like it apparentlyhas been with the Corvair from time to time.I believe I saw one of theplanes at Brodhead with a Model A running some type of metal blade adjustableprop.I wonder if they're not better off with a light wood prop like the Corvairor if they run better with a heavy one to act as a flywheel.RaymondRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sun, 2 Aug 2009 18:24:08 -0700 (PDT)
