Pietenpol-List: Re: if for any other reason than this-- keep building
Original Posted By: "K5YAC"
Subject: Pietenpol-List: if for any other reason than this-- keep building andenjoy the view when you're done Gorgeous, lush farm country somewhere in northern Illinois on Saturday morning headingfrom Joliet, IL. You don't see this kind of view from the aisle seat on a 737. (and you don't get Sprite or Diet Coke either--unless you take it in the seat with you !) Mike C. ________________________________________________________________________________Subject: Pietenpol-List: Re: if for any other reason than this-- keep buildingand enjoy
Maybe I missed it, but you must have recovered your photos. That is a neat shot...looks like a good place to practice emergency procedures.--------Mark - working on wingsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: if for any other reason than this-- keep buildingand enjoy
WOW What a view. Reminds me of late sixties early seventies flying a 450 Stearmanspraying potato bugs just East of Palatka, Fl. Building rib #23Jerry DotsonRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 05 Aug 2009 16:11:53 -0400
Pietenpol-List: Re: Cable-hardware store vs. certified
Original Posted By: "Baldeagle"
Anyone with information on using hardware store cable vs. the certified stuff.I see there is lots of difference in the price; what about the strength and quality?Thoughts? Experience?WillRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Cable-hardware store vs. certified
Re: Pietenpol-List: if for any other reason than this-- keep building
I wouldn't do it, that cheap stuff is crud. Saving a few bucks that way isn'tworth it.-Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 5 Aug 2009 18:04:09 -0400Subject: Re: Pietenpol-List: if for any other reason than this-- keep buildingand enjoy the view when you're done
RE: Pietenpol-List: Cable-hardware store vs. certified
Will,I agree with Baldeagle! It has been stated before, by veteran builders, tostick with AN hardware as much as possible. There are exceptions, such asthe use of motorcycle links to make attachments, but the strength of thelinks are well demonstrated.How far along are you in your project?Gary BootheCool, Ca.PietenpolWW Corvair ConversionTail done, Fuselage on gear(13 ribs down.)-----Original Message-----
Re: Pietenpol-List: Cable-hardware store vs. certified
Subject: Re: Pietenpol-List: Cable-hardware store vs. certifiedAre you building a certified aircraft? Then you don't need certified cable. Is it strong enough ? I dare say you would pull apart what ever it's hook to before the cable would break. Buy a piece and test it to put your mind at ease.Howdy________________________________________________________________________________
One difference between aircraft cable and hardware store cable is thelubricant that is impregnated into the aircraft cable (one reason you shouldnever wash your cable with a solvent - it will leach the lubricant out ofit). This lubricant is necessary to allow bending the cable over pulleyswithout chafing the individual strands.Ask Fisherman Ray how his Pietenpol is coming. He was building itexclusively with materials from Home Depot.Jack PhillipsNX899JPRaleigh, NC _____
