Re: Pietenpol-List: Larry Williams-type brakes
RE: Pietenpol-List: Larry Williams-type brakes
John,I did my best to copy Larry's brake set up, though I have a different drum.The hook up to the heel brake occurs under the floor board as I have bellyformers that allow room for that. All of the adjusters to the cables arehome-made and I would be happy to send you more info if you wish. I even ranthe anti-rotation rod thru the blocks, like Larry's.Gary BootheCool, Ca.PietenpolWW Corvair ConversionTail done, Fuselage on gear(13 ribs down.) _____
