Original Posted By: Dan Yocum
Michael C. I plan to keep the same length of lateral wing sections=3B but I will need to widen the center section of three piece wing to match width of fuselage. I will be looking at a 0-200 engine as the altitude at home airport is often 6000 feet on hot day. Gross weight will be empty weight plus my weight and fuel and oil. Should be under 1000 pounds. Thanks for comments. Big Steve_________________________________________________________________Windows Live: Make it easier for your friends to see what you=92re up to on Facebook.http://windowslive.com/Campaign/SocialN ... ______Date: Wed, 26 Aug 2009 13:11:13 -0500
