Original Posted By: "at7000ft"
Go to http://www.westcoastpiet.com/construction.htmThe second link down,"Simplified Wing Stress Analysis.pdf "is probably the articleKen is thinking about. It's a 10 meg PDF so be warned.Chris--------Chris TracySacramento, CAWestCoastPiet.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Tail feather drain holes
Question for anyone who has finished covering. How many drain grommets did youput on your tail feather panels and where did you put them?ThanksRick, busy rib lacing.--------Rick HollandRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Tail feather drain holes
Hi RickI put one next to each rib and on the rudder at the very bottom point.Dick N.----- Original Message -----
