Pietenpol-List: Riblett 612 plans needed
Posted: Mon Nov 23, 2009 1:55 am
Original Posted By: "hatcherr"
Subject: Pietenpol-List: Tools Nomenclature> > This may have appeared earlier, but with many of us retreating > from the cold weather into our shops, we may need to refresh our > knowledge of tools terminology...> Fred B.> La Crosse, WI> > DRILL PRESS: A tall upright machine useful for suddenly snatching > flat metal bar stock out of your hands so that it smacks you in > the chest and flings your beer across the room, denting the > freshly painted project which you had carefully set in the corner > where nothing could get to it.> WIRE WHEEL: Cleans paint off bolts and then throws them somewhere > under the workbench with the speed of light. Also removes > fingerprints and hard earned calluses from fingers in about the > time it takes you to say, Oh sh > ELECTRIC HAND DRILL: Normally used for spinning pop rivets in > their holes until you die of old age.> SKILL SAW: A portable cutting tool used to make studs too short.> PLIERS: Used to round off bolt heads. Sometimes used in the > creation of blood-blisters.> BELT SANDER:An electric sanding tool commonly used to convert > minor touch-up jobs into major refinishing jobs.> HACKSAW: One of a family of cutting tools built on the Ouija board > principle. It transforms human energy into a crooked, > unpredictable motion, and the more you attempt to influence its > course, the more dismal your future becomes.> VICE-GRIPS: Generally used after pliers to round off bolt heads > entirely. If nothing else is available, they can also be used to > transfer intense welding heat to the palm of your hand.> OXYACETYLENE TORCH: Used almost entirely for lighting various > flammable objects in your shop on fire. Also handy for igniting > the grease inside the wheel hub out of which you want to remove a > bearing race.> TABLE SAW: A large stationary power tool commonly used to launch > wood projectiles for testing wall integrity. (And the inside of my > garage can prove it.)> HYDRAULIC FLOOR JACK: Used for lowering an automobile to the > ground after you have installed your new brake shoes, trapping the > jack handle firmly under the bumper.> BAND SAW: A large stationary power saw primarily used by most > shops to cut good aluminum sheet into smaller pieces that more > easily fit into the trash can after you cut on the inside of the > line instead of the outside edge.> TWO-TON ENGINE HOIST: A tool for testing the maximum tensile > strength of everything you forgot to disconnect.> PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under > lids or for opening old-style paper-and-tin oil cans and splashing > oil on your shirt; but can also be used, as the name implies, to > strip out Phillips screw heads.> STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes > used to convert common slotted screws into non-removable screws > and butchering your palms.> PRY BAR: A tool used to crumple the metal surrounding that clip or > bracket you needed to remove in order to replace a 50 part.> HOSE CUTTER: A tool used to make hoses too short.> HAMMER: Originally employed as a weapon of war, the hammer > nowadays is used as a kind of divining rod to locate the most > expensive parts adjacent the object you are trying to hit.> UTILITY KNIFE: Used to open and slice through the contents of > cardboard cartons delivered to your front door; works particularly > well on contents such as seats, liquids in plastic bottles, > collector magazines, refund checks, and rubber or plastic parts. > Especially useful for slicing work clothes, but only while in use.> DAMM-IT TOOL: Any handy tool that you grab and throw across the > garage while yelling DAMM-IT at the top of your lungs. It is > also, most often, the next tool that you will need.> > > > ________________________________________________________________________________Subject: Pietenpol-List: Riblett 612 plans needed
Pietenpol-List: Re: Riblett 612 plans needed
Posted: Mon Nov 23, 2009 10:16 pm
coxwelljon wrote:> Hello,> > Do you have access to a CADD program?- If so here is a link to a DWG file for the 612 airfoil.> That is the link to the wrong 612 Airfoil. That's what happens when you use the short names. Airfoil on that site is GA37-612, and for AirCampers it is recommended to use GA30-612.I've attached to this message DXF and PDF files I've maid, with correct airfoil. Use them, or pay for the drawings somebody is selling on this list. That drawing has full rib details, although spar distance and other details are drawn for classic Pietenpol, I guess you'll have to draw your own for GN-1.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/ga30 ... _872.pdfle, List Admin.=0A=0A=0A ________________________________________________________________________________Date: Sun, 06 Dec 2009 22:27:41 -0500
Posted: Mon Nov 23, 2009 10:58 pm
Hello,Do you have access to a CADD program? If so here is a link to a DWG file for the 612 airfoil. http://www.davincitechnologies.com/Airf ... rfoils.htm. You can download the file and plot it out. If you don't have access to a cad program let me know and I could load the file and convert it to a PDF file which you could have printed in full size at any Staples outlet or other print shop. Let me know if I can help.I am also building a GN-1. A project I bought that I am completing.Jon Coxwell--------Jon CoxwellRecycle and preserve the planetRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Riblett 612 plans needed
Posted: Mon Nov 23, 2009 10:59 pm
Hello,Do you have access to a CADD program? If so here is a link to a DWG file for the 612 airfoil. http://www.davincitechnologies.com/Airf ... rfoils.htm. You can download the file and plot it out. If you don't have access to a cad program let me know and I could load the file and convert it to a PDF file which you could have printed in full size at any Staples outlet or other print shop. Let me know if I can help.I am also building a GN-1. A project I bought that I am completing.Jon Coxwell--------Jon CoxwellRecycle and preserve the planetRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 24 Nov 2009 00:09:10 -0800
Posted: Tue Nov 24, 2009 3:16 am
coxwelljon wrote:> Hello,> > Do you have access to a CADD program? If so here is a link to a DWG file forthe 612 airfoil.> That is the link to the wrong 612 Airfoil. That's what happens when you use theshort names. Airfoil on that site is GA37-612, and for AirCampers it is recommendedto use GA30-612.I've attached to this message DXF and PDF files I've maid, with correct airfoil.Use them, or pay for the drawings somebody is selling on this list. That drawinghas full rib details, although spar distance and other details are drawnfor classic Pietenpol, I guess you'll have to draw your own for GN-1.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/ga30 ... __________
Posted: Wed Nov 25, 2009 8:52 am
Pietenpol-List: Re: How to be a proper Pietenpol passenger
Posted: Wed Nov 25, 2009 11:16 am
Original Posted By: "K5YAC"
Seven steps to becoming a proper Pietenpol passenger- Step #1 - Left foot on tire, one hand on each cabane........------------------------------------------------------------------------------ Step #2 Head and shoulders go all the way through the cockpit as you step in with your right foot.........------------------------------------------------------------------------------ Step#3 - Put on your seatbelt, goggles and earplugs......... ------------------------------------------------------------------------------ Step #4 - Relax and get ready to enjoy your flight........... ------------------------------------------------------------------------------ Step #5 - Enjoy the pretty, rural towns from the air........... ------------------------------------------------------------------------------ Step #6 - After landing, thank your pilot for a nice flight............. ------------------------------------------------------------------------------ Step #7 - Tell the world what you think of Pietenpols! ------------------------------------------------------------------------------________________________________________________________________________________Subject: Pietenpol-List: Re: How to be a proper Pietenpol passenger
Posted: Wed Nov 25, 2009 12:39 pm
Original Posted By: Jim
Rub it in Greg... rub it in.--------Mark - working on wingsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 25 Nov 2009 20:17:07 +0000 (GMT)
RE: Pietenpol-List: Fw: How to be a proper Pietenpol passenger
Posted: Wed Nov 25, 2009 4:01 pm
Greg,I'm crushed! You didn't smile at me like that....but, then, I'm not quite so purtee.Happy Thanksgiving,Gary BootheCool, Ca.PietenpolWW Corvair Conversion, mountedTail done, Fuselage on gear(15 ribs down.) _____
Re: Pietenpol-List: Fw: How to be a proper Pietenpol passenger
Posted: Wed Nov 25, 2009 7:33 pm
Hi Gary,I'll smile when your legs look as nice.........Greg ----- Original Message -----
Posted: Mon Dec 07, 2009 5:25 am
Original Posted By: airlion
I've got them from John Woods table, I wrote to him and in e-mail he confirmedto me that they are from the book. Don't worry, these coordinates are correct,they can also be found on several reliable places. There are two other sets of612 coordinates roaming around the Internet with slightly different trailingedge coordinates.Coordinates for 613.5 where a bigger challenge to confirm that there are correct,I've found only two other aircraft except AirCamper who use this airfoil, butfinally I've found one other source of coordinates to confirm the table. So,I've posted here the drawings I've made from John's coordinates for both airfoilsand, as far as I'm concerned, consider them correct and I'm going to buildusing them. I would love if someone triple check them.Ivanaircamperace(at)yahoo.com wrote:> Ivan, where did you get your coordinates from. There seems to be a bit of confusionout there. I bought Riblet's book and the GA30-612 wasn't in thereRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 7 Dec 2009 06:16:00 -0800 (PST)
Posted: Mon Dec 07, 2009 9:23 am
The best place I've found to do price comparisons is MySimon.Take a look at the various quantities of T-88 at the places shown here:http://www.mysimon.com/find/T-88+EpoxyTK--------Tom KreinerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Riblett 612 plans needed
Posted: Mon Dec 07, 2009 9:32 am
Ivan,The GA30-612 Stations and Ordinates are shown on page 58 of the GA Airfoils book by Harry Riblett. As with all airfoil tables, these are set at 100% chord, and in order to use, willneed to be converted to the 60 in. chord if that's what you want to use asyour chord length. If you don't know how to convert, contact me offline, andI'll send you the calculated Stations and Ordinates. This is very easily donewith an Excel spreadsheet.When you go to plot, you will need to remember that there are both positive andnegative Ordinates, shown in the tables as "upper" and "lower."Hope this helps.TK--------Tom KreinerRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Riblett 612 plans needed
Posted: Mon Dec 07, 2009 11:00 am
Original Posted By: Ken Howe
Ryan Mueller wrote:> http://lmgtfy.com/?q=t-88+epoxy (http://lmgtfy.com/?q=t-88+epoxy)> That is hilarious. Gotta keep that one handy.--------Mark - working on wingsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Riblett 612 plans neededDate: Mon, 07 Dec 2009 10:30:03 -0700
Posted: Mon Dec 07, 2009 12:10 pm
Original Posted By: Dan Yocum
