Good morning,Should I cut them per plans or lengthen a bit?Thanks!JackDSM________________________________________________________________________________
Pietenpol-List: Center Strut Fittings
RE: Pietenpol-List: Center Strut Fittings
Jack,Mike Cuy suggested cutting all fittings longer. Mine are =BD=94 longer. Itreally helps in getting the cables hooked up.Gary BootheCool, CAPietenpolWW Corvair ConversionTail done, Fuselage on gear18 ribs done
