Pietenpol-List: simple mixing of T-88
Pietenpol-List: Re: simple mixing of T-88
Original Posted By: Dan Yocum
Subject: Pietenpol-List: Re: simple mixing of T-88[quote="aadamson1(at)centurytel.n"]Hey guys, With all due respect to everyones suggestions for mixing T-88. The simplest thingto do isgo to Fleet-Farm (or another farm supply store) and buy the largestsyringes available. I buy 30cm size. Pour part A in one syringe and part Bin a second syringe. They are marked in cms so mixing is accurate, are easyto use, are inexpensive and readily available. Thats the only way Id mix T-88. Arden Adamson New London, WI > I saw my fellow EAA'r last night and asked him what he had used. He is buildingHatz classic wings. He is frugal, methodical and smart. He buys buys doublebarrel syringes from McMastars-Carr (on line) along with mixing tips, and cleansthem by soaking them in a closed container of MEK. Said he is able to getmultiple uses out of the syringes and tips.I use white vinegar for T-88 clean up but I don't know if it would clean it outof a syringe.Jon Coxwell--------Jon Coxwell GN-1 BuilderRecycle and preserve the planetRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 09 Apr 2010 09:15:49 -0500
Original Posted By: Jeff wilson
Hey guys,With all due respect to everyone's suggestions for mixing T-88. Thesimplest thing to do is-go to Fleet-Farm (or another farm supply store) andbuy the largest syringes available. I buy 30cm size. Pour part A in onesyringe and part B in a second syringe. They are marked in cm's so mixingis accurate, are easy to use, are inexpensive and readily available. That'sthe only way I'd mix T-88.Arden AdamsonNew London, WI________________________________________________________________________________
aviatorbell(at)yahoo.com wrote:> Jon, my wife bought a motercycle after I had mine for a couple years. Ironicallyshe is the one who sold hers right after we got maried, not me? I shouldhave plenty of room for 2 bikes and a tent. Where are you riding in from? > > ShadI would be coming from Remsen NY, 20 miles North of Utica. About 650 miles. Weride huge bikes, a 1982 Honda Twinstar 200 and a 250 Honda Helix. At the endof the day you just lay down and vibrate for 10 minutes.Jon Coxwell--------Jon Coxwell GN-1 BuilderRecycle and preserve the planetRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: simple mixing of T-88
Original Posted By: shad bell
[quote="aadamson1(at)centurytel.n"]Hey guys, With all due respect to everyones suggestions for mixing T-88. The simplest thingto do isgo to Fleet-Farm (or another farm supply store) and buy the largestsyringes available. I buy 30cm size. Pour part A in one syringe and part Bin a second syringe. They are marked in cms so mixing is accurate, are easyto use, are inexpensive and readily available. Thats the only way Id mix T-88. Arden Adamson New London, WI > I saw my fellow EAA'r last night and asked him what he had used. He is buildingHatz classic wings. He is frugal, methodical and smart. He buys buys doublebarrel syringes from McMastars-Carr (on line) along with mixing tips, and cleansthem by soaking them in a closed container of MEK. Said he is able to getmultiple uses out of the syringes and tips.I use white vinegar for T-88 clean up but I don't know if it would clean it outof a syringe.Jon Coxwell--------Jon Coxwell GN-1 BuilderRecycle and preserve the planetRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Thu, 8 Apr 2010 12:31:53 -0700 (PDT)
Well, I must be REALLY frugal then, because I don't buy any syringes. But then,I don't use any syringes, either. Just a simple, cheap, graduated clear plasticmedicine cup (like others have mentioned), and a re-usable plastic mixing stick/spreader.Really simple, and really easy, and I don't use any MEK (that stuffis toxic, you know) or even vinegar, because THERE IS NO CLEANUP. Just leavethe little bit in the bottom of the mixing cup, label it with the date, andkeep it as a record of your glue sample. The bit of epoxy that is left on themixing stick flakes off when fully cured, and the stick gets re-used.The syringes just seem like WAY more work that they're worth.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Thu, 08 Apr 2010 15:30:23 -0500
Re: Pietenpol-List: Re: simple mixing of T-88
Oh no here at mickey Ds and gonna Markle some of the plastic coffee stirrers tomix and apply my epoxy. Oh no I feel the Markle over taking me as I am unavoidably compelled. Must Markle stirrers, must markle,must markel, mmmmmuuuuuusssssssttttt mmmmmaaaaaarrrrkkkkllllenoooow.........Sent from my Verizon Wireless BlackBerry-----Original Message-----
