Original Posted By: "899PM"
OK, so I know everyone is in "waiting for Brodhaed" mode, but I'm posting this for all of you who can't get there this year (like me), or just need yet another event to fly to this summer.Hope to see you there!Kip GardnerSubject: EAA 82 WINGS AND WHEELS FLY-IN, Part TwoLast month, June 5th & 6th, EAA Chapter 82 had scheduled our annual Wings and Wheels Fly-in, but the weather didn't cooperate.We have re-scheduled the fly-in in conjunction with the annual Taylotcraft / Aeronca Fly-in which is also held annually at Barber Field (2D1).It will be held on July 10th and 11th.The field is located approximately three miles north of Alliance, Ohio on State Route 225. There will be aircraft with automotive and alternative engines - CORVAIRS AND VOLKSWAGENS on display.There will be a pancake breakfast on Saturday and Sunday from 7 till 11 AM with lunch on Saturday from noon till 2 PM. This event is open to the public.There will be homebuilt aircraft ( KR-2S's, Pietenpols, an Afford-a- Plane), PRA #19 (Rotorcraft Chapter) will have trikes and a demonstrator, and Vintage and Antique aircraft (Waco 9, Fleet, Taylorcraft, Aeronca) on the field. There will be a fleet of some nicely restored Corvair cars on display. Mark Langford, Larry Flesner, Mark Jones and Joe Horton are planning on being there, provided the weather and their schedules permit. There will be several Corvair engines and a "Roy's Garage" Fifth Bearing on display for those who are interested in using a Corvair in their project. Roy Szarafinski of Roy's Garage WILL RETURN to answer questions about his bearing and will gladly check your ENGINE CASES AND CRANKS for proper tolerances before you start an engine rebuild. The fly-in hours will be Saturday... 7 AM - 4 PM and Sunday... 7 AM - 2 PM. For more information, contact Ron Willett @ 330-314-0075 or Pete Klapp @ 330-388-2074, and Forrest Barber (FBO) at WWW.BARBERAIRCRAFT.COM. We can provide lodging for those who would be flying in for our event.Hope to see many fellow EAA faces present at our fly-in.Thanks, Pete Klapp, building KR-2S, N729PK,Canton, Ohio________________________________________________________________________________Subject: Pietenpol-List: MODEL A CARBS AND CARB HEAT
Original Posted By: H RULE
For those of you running Model A's....what carb are you using? What drop have youseen with the application of carb heat. With the only other change being fromauto gas to 100LL I saw a drop of 110rpm after hooking up the carb heat yesterday.This seems excessive. Was turning 1860rpm with a 76-42 Sensenich woodprop. Could only get 1750 yesterday.--------PAPA MIKERead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/img_ ... ______Date: Tue, 6 Jul 2010 10:26:25 -0700 (PDT)
Re: Pietenpol-List: MODEL A CARBS AND CARB HEAT
Mike :If you pull the hose off the heater does the RPM change ? What RPM difference does the fuel change make ?Is the lower RPM only on 100LL ?Is the carb acting up again ?The Funk engine uses a down draft Zenith.Douwe and I have used a two venturi Weber with great success.The larger venturi the better, with smooth ducting.Carbs from Cont, will work but will need Carb heat with a diverter box to get themost HP on take-off.Pieti LowellRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: MODEL A CARBS AND CARB HEATDate: Tue, 06 Jul 2010 20:37:51 -0400
Pietenpol-List: Re: Harvey Rule's Ethanol Rant
Original Posted By: "tkreiner"
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________________________________________________________________________________Subject: Pietenpol-List: Re: Harvey Rule's Ethanol Rant
Pietenpol-List: Re: MODEL A CARBS AND CARB HEAT
Steve chase9240 Catterton Ct.Owings, MD 20736Long Fuselage Piet...almost on gearA-65 in the garage--------Stevewww.mypiet.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: MODEL A CARBS AND CARB HEAT
