Original Posted By: H RULE
Guys, Had something new happen tonight on the GN-1 I purchased last month. I flew forabout 1-3/4 hour, it was about 82 degree's out. When I landed and shut the engineoff - it just sat their and "dieseled" on me. I don't have a fuel mixturecutoff installed on this plane - and it takes about 4-5 minutes of idling beforeit will shut down after fuel valve shutoff - so I sat and played with thethrottle and occasionally flipped one or both mags on/off again (to see if Ihad a P-lead issue). I didn't hear any difference in engine dieseling or run duringthis play around period. It would almost shut off - just not quite...When I was finally able to get it to quit after about 4 minutes or so (I thinkit finally ran out of fuel), I chocked the wheels, made sure mags were off, andtried to hand prop it. The bugger tried to start on me.I run premium BP auto fuel (no ethanol mix).If memory serves me, I've got the Marvel MA3 on it (still learning this stuff).I've got about 8.5 hours on this plane now, this is the first I've seen this happen.Any comments on troubleshooting, I'd sure appreciate it.Lorin--------Lorin MillerWaiex N81YXGN-1 N30PPRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 16 Jul 2010 21:50:29 -0700 (PDT)
Pietenpol-List: Cont. A-75 Run-On
Re: Pietenpol-List: Cont. A-75 Run-On
Lorin,What type of mag switch do you have? I had an A-7 corrode and go bad on me. They are old and notorious for that. Easy to fix but just something to think about.-john-John HofmannVice-President, Information TechnologyThe Rees Group, Inc.2424 American LaneMadison, WI 53704Phone: 608.443.2468 ext 150Fax: 608.443.2474Email: jhofmann(at)reesgroupinc.comOn Jul 16, 2010, at 11:31 PM, ldmill wrote:> > Guys,> Had something new happen tonight on the GN-1 I purchased last month. I flew for about 1-3/4 hour, it was about 82 degree's out. When I landed and shut the engine off - it just sat their and "dieseled" on me. I don't have a fuel mixture cutoff installed on this plane - and it takes about 4-5 minutes of idling before it will shut down after fuel valve shutoff - so I sat and played with the throttle and occasionally flipped one or both mags on/off again (to see if I had a P-lead issue). I didn't hear any difference in engine dieseling or run during this play around period. It would almost shut off - just not quite...> > When I was finally able to get it to quit after about 4 minutes or so (I think it finally ran out of fuel), I chocked the wheels, made sure mags were off, and tried to hand prop it. The bugger tried to start on me.> > I run premium BP auto fuel (no ethanol mix).> > If memory serves me, I've got the Marvel MA3 on it (still learning this stuff).> > I've got about 8.5 hours on this plane now, this is the first I've seen this happen.> > Any comments on troubleshooting, I'd sure appreciate it.> > Lorin> > --------> Lorin Miller> Waiex N81YX> GN-1 N30PP> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 154#305154> > > > > > > > > > ________________________________________________________________________________Subject: Re: Pietenpol-List: Cont. A-75 Run-On
