Pietenpol-List: Weather report: Forecast for Brodhead next week...looooooooking
Just turn the fuel valve off and let it idle until the gas burns out of the carb.It will die. That is what I used to do on the Luscombe I had. Works every time.--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009Ribs and tailfeathers doneusing Lycoming O-235Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Weather report: Forecast for Brodhead next week...looooooookinggooood !!Date: Sat, 17 Jul 2010 07:37:52 -0400
Re: Pietenpol-List: Weather report: Forecast for Brodhead next week...looooooooking
Looking good... for a sweat lodge...-- yocum(at)gmail.comOn Jul 17, 2010, at 6:37 AM, helspersew(at)aol.com wrote:> Not too bad. I'll take the heat in lieu of all-day rain.> > Wednesday:> HI 88=C2=B0> LO 74=C2=B0> Quite warm and humid. Convective clouds build into clusters of thunderstorms. Locally heavy downpours likely. Southerly winds 10 to 15 mph.> > Thursday:> HI 97> LO 77> Mostly sunny, breezy southwest winds, hot and humid. Isolated afternoon thunderstorms possible. Heat indexes of 100 degrees or higher> > Friday:> Partly cloudy> HI 98=C2=B0> LO 77=C2=B0> Mostly sunny, intensely hot and humid. Highs in the upper 90s with a local 100-degree reading possible. Heat index again exceeds 100 degrees> > Dan Helsper> Poplar Grove, IL.> > ============================================================================================================================================> ________________________________________________________________________________Date: Sat, 17 Jul 2010 06:06:55 -0700 (GMT-07:00)
