Pietenpol-List: 1.5mm Plywood
Re: Pietenpol-List: 1.5mm Plywood
Original Posted By: tkreiner
There is a fellow at Boulter that is a bit fast ,,,, watch for damaged goods whitch he will pawn off on you at least if you are a walk in customer....
Original Posted By: "tkreiner"
Of course, I call BS. More like you need a *motor mount* to hang the engine on that piece art you'vegot going. ;-)Dan-- Dan Yocumyocum137(at)gmail.com"I fly because it releases my mind from the tyranny of petty things."On Oct 15, 2010, at 6:42 PM, Jerry Dotson wrote:> > My engine is almost ready to run. Several loose ends on it yet. I just hungthe mags and valve covers on it. I have been working on that thing for a monthnow. I got the wrong main bearings and had to exchange them but that didn't reallycost much time. I got my prop from Jay Anderson and it looks real good.Now if I just had an airplane to hang all this stuff on............> > --------> Jerry Dotson> 59 Daniel Johnson Rd> Baker, FL 32531> > ________________________________________________________________________________Subject: Pietenpol-List: 1.5mm Plywood
