Pietenpol-List: Wood Gear Cable Placement
Re: Pietenpol-List: Wood Gear Cable Placement
Michael,By your own admission, these cables are not necessary, so why would you want them on there?Dan HelsperPoplar Grove, IL.-----Original Message-----
Not only is it not necessary, it would interfere with axle travel. Plus, if you look at the cable connections from a top view you will see that they are pretty much already doing what you propose.Greg C. ----- Original Message -----
Re: Pietenpol-List: Re: Tail wheel
Original Posted By: Earnest Bunbury
Subject: Re: Pietenpol-List: Re: Tail wheel
