I lifted this idea from Rick Holland, and have mentioned it before, butsince you ask.If you have a battery, or even if you don't, you can use a smallrechargeable.I purchased a Ray Allen trim servo which weighs a few ounces and mounts inthe elevator to actuate a tab. Two tiny wires run up to a rocker switch and"Bob's your Uncle!!" you're done!! Light, nothing seen cluttering thecockpit and. Easey Peasey, Lemon Squeezey.Very un-original, BUT so is anything else, but it's much easier to hide thanany other system other than a ground adjustable (bend) tab.Available through ACS and many others.Douwe________________________________________________________________________________
