Pietenpol-List: powder coating
Watch seconds :30 - :50https://www.youtube.com/watch?v=5nIywIgxevI> Roads at the ends of runways are BAD. Didn't a P51 hit a pickup truck at > Brodhead? I know some airplane at Pioneer field clipped the top of the > tram that goes from the museum to the airfield. I witnessed a crop duster > take off (overweight) and would have hit a car if it were there. Got to > be a million more cases, just not many on video...________________________________________________________________________________Subject: Pietenpol-List: powder coating
I forget who raised the question about powder coating, but my usual go-by is MarkLangford. If he's done it before, I go look at his method and results first.He powder-coated various parts of his engine (and other items) and describesthe process in general about halfway down this page:http://www.n56ml.com/corvair/phoenix/--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 7 Nov 2012 03:55:17 -0800 (PST)
Pietenpol-List: Re: powder coating
Original Posted By: "tools"
Uncle Tony rules...Sent from my iPadJack TextorOn Feb 27, 2013, at 7:15 AM, "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" wrote:> > Way to go Jack Textor in painting your Pietenpol motor mount white! Only afterI had painted mine black did I read the section> Tony Bingelis wrote on motor mount fabrication and he suggests to paint the mountswhite to make finding cracks easier. Brilliant> but I didn't do it. Smart move Jack and you're one of the very few who hascaught that wisdom and applied it in your building> process. > > It looks like you're doing exceptional work Jack and yours is another that Ireally look forward to seeing in the coming years at Brodhead. > > Mike C.> > > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: powder coating
Well, me too on hearing (all from EAA staff A&P's) that powder coating hides cracks,so they don't like it. I am NOT relaying my opinion on whether or not it's a good idea or not, mostlybecause I have no clue! These guys pretty much only play with old stuff, finding and fixing cracks andsuch. BUT, I hate how all the small parts on my Piet (like the flat plate fittings thatdon't even have welding on them) eventually get looking "icky" and I'm prettysure they'd stay nicer looking if powder coated. I fly off a lot of grass and everything on the bottom side gets wet. Seems thecorrosion prevention would be an asset not yet mentioned.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 27 Feb 2013 06:10:03 -0800 (PST)
Re: RE: Pietenpol-List: corvair eyebrows
Gary, I am assuming that the eight washers move the fine 1/2 inch (1/16 inch for each washer). Correct? If so and you were rebuilding right now how many more washers would you use? I am at the point of displacing my fin and might as well get it correct the first time. Chuck----- Original Message -----
Original Posted By: "Ken Bickers"
Ken, I just asked Gary the same thing. I would think off hand that 3/4 inch would be a bit much. I'm thinking of about 5/8 inch. Most of the posts I have read from people who use a smaller Continental engine I gather that they are offsetting the fin about 1/2 inch. I'm thinking that if Gary used regular thickness AN washers he displaced his fin 1/2 inch also which, as he said, is not quite enough. I would think that with 3/4 inch you would have to hold a slight amount of right rudder in cruise which would be counterproductive. Chuck----- Original Message -----
Original Posted By:> ----- Original Message ----- "Gary Boothe"
Think I would shoot for 3/4", Chuck.GarySent from my iPhoneOn Feb 27, 2013, at 6:18 AM, "C N Campbell" wrote:> > Gary, I am assuming that the eight washers move the fine 1/2 inch (1/16 inchfor each washer). Correct? If so and you were rebuilding right now how manymore washers would you use? I am at the point of displacing my fin and mightas well get it correct the first time. Chuck>
Original Posted By: Mario Giacummo
That looks great LarryVery nice work--------Earl BrownI may not have gone where I intended to go, but I think I have ended up where Iintended to be.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Original Posted By:>>> TOM STINEMETZE > Subject: Re: RE: Pietenpol-List: corvair eyebrows>> To: pietenpol-list(at)matronics.com>>>>>>>>>> Whoops, my bad. A Corvair normally turns clockwise when viewed from the>>> front.>>>>>> Stinemetze>>>>>>>>> >>> "Dortch, Steven D MAJ MIL USA NGB" >>>>> >>>>> Which way does a crank snapper rotate?>>>>>> Normally a plane in climb with a real engine (I am a contenental snob.)>>> climbs with the prop pushing more air in the right side than the left >>> due>>>> to the relative angle of the blade to the wind. Resulting in cooler >>> temps>>>> on the right side.>>>>>> Blue Skies,>>> Steve D>>>>>> ----- Original Message -----
>>> Subject: RE: Pietenpol-List: corvair eyebrows>>> To: pietenpol-list(at)matronics.com>>>>>>>>> > Barry and Rick:>>> >>>> > I recall reading a post by William Wynne where he discusses the>>> > advantages of having the two eyebrow areas interconnected for more>>> > balanced>>> > cooling. I don't remember all of his reasoning but it included>>> > the cooling difference per inlet in a climb attitude caused by the>>> > reduced pitch of the upward moving blade compared to the increased>>> > pitch of the downward moving blade. As a consequence, the hottest>>> > side of the Corvair engine in the highest power regime (climb) is>>> > the right cylinder bank which is where detonation normally occurs>>> > first. He suggested, at the very least, connecting the two sides>>> > via a scat tube to allow the higher pressure side to help cool the>>> > lower pressure side.>>> >>>> > Has anybody on the list tried this?>>> >>>> > Tom Stinemetze>>> > N328X>>> > McPherson, KS.>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ________________________________________________________________________________
Original Posted By:>>>> TOM STINEMETZE >> Subject: Re: RE: Pietenpol-List: corvair eyebrows>>> To: pietenpol-list(at)matronics.com>>>>>>>>>>>>>> Whoops, my bad. A Corvair normally turns clockwise when viewed from >>>> the>>>> front.>>>>>>>> Stinemetze>>>>>>>>>>>> >>> "Dortch, Steven D MAJ MIL USA NGB" >>>>>> NGB">>>> >>>>>>> Which way does a crank snapper rotate?>>>>>>>> Normally a plane in climb with a real engine (I am a contenental snob.)>>>> climbs with the prop pushing more air in the right side than the left >>>> due>>>>>> to the relative angle of the blade to the wind. Resulting in cooler >>>> temps>>>>>> on the right side.>>>>>>>> Blue Skies,>>>> Steve D>>>>>>>> ----- Original Message -----
Re: Pietenpol-List: corvair eyebrows
>>>> Subject: RE: Pietenpol-List: corvair eyebrows>>>> To: pietenpol-list(at)matronics.com>>>>>>>>>>>> > Barry and Rick:>>>> >>>>> > I recall reading a post by William Wynne where he discusses the>>>> > advantages of having the two eyebrow areas interconnected for more>>>> > balanced>>>> > cooling. I don't remember all of his reasoning but it included>>>> > the cooling difference per inlet in a climb attitude caused by the>>>> > reduced pitch of the upward moving blade compared to the increased>>>> > pitch of the downward moving blade. As a consequence, the hottest>>>> > side of the Corvair engine in the highest power regime (climb) is>>>> > the right cylinder bank which is where detonation normally occurs>>>> > first. He suggested, at the very least, connecting the two sides>>>> > via a scat tube to allow the higher pressure side to help cool the>>>> > lower pressure side.>>>> >>>>> > Has anybody on the list tried this?>>>> >>>>> > Tom Stinemetze>>>> > N328X>>>> > McPherson, KS.>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ________________________________________________________________________________Subject: Re: Pietenpol-List: corvair eyebrows
Original Posted By:>>>> TOM STINEMETZE >> Subject: Re: RE: Pietenpol-List: corvair eyebrows>>> To: pietenpol-list(at)matronics.com>>> >>> >>>> >>>> Whoops, my bad. A Corvair normally turns clockwise when viewed from the>>>> front.>>>> >>>> Stinemetze>>>> >>>> >>>> >>> "Dortch, Steven D MAJ MIL USA NGB" >>>>>> >>> >>>> Which way does a crank snapper rotate?>>>> >>>> Normally a plane in climb with a real engine (I am a contenental snob.)>>>> climbs with the prop pushing more air in the right side than the left due>> >>>> to the relative angle of the blade to the wind. Resulting in cooler temps>> >>>> on the right side.>>>> >>>> Blue Skies,>>>> Steve D>>>> >>>> ----- Original Message -----
Pietenpol-List: Re: motivation
>>>> Subject: RE: Pietenpol-List: corvair eyebrows>>>> To: pietenpol-list(at)matronics.com>>>> >>>> >>>> > Barry and Rick:>>>> >>>>> > I recall reading a post by William Wynne where he discusses the>>>> > advantages of having the two eyebrow areas interconnected for more>>>> > balanced>>>> > cooling. I don't remember all of his reasoning but it included>>>> > the cooling difference per inlet in a climb attitude caused by the>>>> > reduced pitch of the upward moving blade compared to the increased>>>> > pitch of the downward moving blade. As a consequence, the hottest>>>> > side of the Corvair engine in the highest power regime (climb) is>>>> > the right cylinder bank which is where detonation normally occurs>>>> > first. He suggested, at the very least, connecting the two sides>>>> > via a scat tube to allow the higher pressure side to help cool the>>>> > lower pressure side.>>>> >>>>> > Has anybody on the list tried this?>>>> >>>>> > Tom Stinemetze>>>> > N328X>>>> > McPherson, KS.>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >> > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: motivation
