Pietenpol-List: CENTER SECTION WEIGHT
Original Posted By: "Allan Macklem"
Subject: Pietenpol-List: CENTER SECTION WEIGHTMY COMPLETED "C" SECTION WEIGHT IS 31 POUNDS, THIS INCLUDES ALUMINUN FUEL TANK,SIGHT GAUGE AND PLUMBING.THIS ALSO INCLUDES A KT 76 AND BOX MOUNTED ON THE BOTTOM SIDE PLUS ANTENNA ON THE TOP COVER FOR THE TANK IS ALUMINUM AND USED AS A GROUND PLANE . THIS WAS WEIGHED WITH DIGITAL SCALES THAT READ TO 400 POUNDS. I AM ALSO GOING TO USE THESE SCALES TO MEASURE THE THRUST FROM MY CORVAIR ENGINE WITHTHE TENNESSEE PROP. TED STONEWILMINGTON, NC________________________________________________________________________________
RE: Pietenpol-List: CENTER SECTION WEIGHT
Ted, sounds like an accomplishment needing recognition. "Good on you!" I'msure people on the list (in addition to me) would value some pictures ofyour progress.Allan MacklemElkhorn, NE
