Pietenpol-List: mechanical tach
Posted: Mon Jan 07, 2013 11:32 pm
If using the mechanical drive off the oil pump like Bernard did, which way does the tach need to rotate, to the right or left? Will any mechanical tach work?Dennis________________________________________________________________________________Date: Wed, 9 Jan 2013 09:11:26 -0800 (PST)
Pietenpol-List: Re: N number vs NX number
Posted: Wed Jan 09, 2013 8:36 am
That's cool. Not sure I need it in Texas, though.--------Kevin "Axel" PurteeNX899KPAustin/San Marcos, TXRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: N number vs NX number
Re: Pietenpol-List: Aviation Ground School
Posted: Wed Jan 09, 2013 8:51 am
Paul,The FAA does NOT issue an NX number. They only issue a straight N number. TheX can be put on the airplane to eliminate the Words Experimental provided thatthe plane is more than 30 years old or is a replica of an aircraft more than30 years old. The Piet is covered by both accounts. None of the aircraft registrationwill indicate the X you are talking about. All paper work will onlyshow the N number. I am at work and don't have my FAR book with me so I cannotquote which reg it is. Perhaps others on the list have it handy.--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 9 Jan 2013 08:59:47 -0600Subject: Re: Pietenpol-List: Aviation Ground School
Posted: Wed Jan 09, 2013 9:04 am
FAR 45.22 (b)Read this topic online here:
Re: Pietenpol-List: Re: N number vs NX number
Posted: Wed Jan 09, 2013 9:09 am
That's the one. Thanks--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 9 Jan 2013 09:15:26 -0600Subject: Re: Pietenpol-List: Re: N number vs NX number
Posted: Wed Jan 09, 2013 11:06 am
Posted: Wed Jan 09, 2013 12:21 pm
