This isnt Piet related so my apologies.Right now My wife and I are doing a fund raiser for St. Josephs Home for Children. This has been a very difficult thing to do and I have been asking a lot from everybody I know. St. Joes is a non profit non deminational childrens home that I have been working with since I delivered some children to them back in the mid 1970's when I was employed by the City of Brooklyn Park, Mn. police dept. They are a wonderful organization and they take children from infants thru 17. Whe my dad diied a couple of years ago he left them a good chunk of money and my wife and I wend shopping for things they really needed, like underwear and socks. The older kids are the ones that are short of that sort of thing. If anyone here on this list wants to support this organization I would appreciate it greatly, you could send any deductable donation to;St. Josephs Home for Children Richard Navratil 1415 Skiles Ln. Arden Hills, Mn. 55112Thanks Dick N.________________________________________________________________________________Date: Sat, 12 Jan 2013 11:21:46 -0700Subject: Pietenpol-List: Panel coamings
Re: Pietenpol-List: Re: Panel coamings
Awesome Ken! Is that copper veneer? If so, did you glue it down as well?John--------John FrancisRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sat, 12 Jan 2013 13:12:45 -0700Subject: Re: Pietenpol-List: Re: Panel coamings
Re: Pietenpol-List: Panel coamings
+1 on Gary's recommendation.--------Mark ChouinardWings, Center Section and Empannage and Fuse framed up - Working on Landing GearRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Panel coamings
Yup, what Gary says.--------John FrancisRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sat, 12 Jan 2013 13:52:24 -0700Subject: Re: Pietenpol-List: Panel coamings
Original Posted By: Jack
Are you based within the Bravo, or inside the Mode C veil?Wayne BresslerTaildraggers, Inc.www.taildraggersinc.comOn Jan 12, 2013, at 3:12 PM, Ken Bickers wrote:> > Yes, John. Copper sheets. A friend had a couple pieces left over> from a home repair project. He gave them to me, thinking maybe I could> use them on the Pietenpol. I'm not sure the thickness, but will be> happy to measure. I'd guess around 0.040. The pieces are attached> with machine screws.> > On the rear panel, each group of instruments is attached to a separate> copper sheet, allowing the instruments to be removed as clusters. On> the aft right hand sheet will later be installed a com and> transponder, which I'll need because the plane is based under a Class> B veil (and because I'll be installing an engine-driven electrical> system).> > On the front panel, the copper pieces are purely decorative, though> the middle one serves as a door to a glove box. They are also> installed with machine screws.> > On Sat, Jan 12, 2013 at 12:17 PM, John Francis wrote:>> >> Awesome Ken! Is that copper veneer? If so, did you glue it down as well?>> >> John>> >> -------->> John Francis>> >> >> >> >> Read this topic online here:>> >> http://forums.matronics.com/viewtopic.p ... 112#392112>> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________Subject: Re: Pietenpol-List: Panel coamings
Original Posted By:> Ken Bickers
Oh no sir it's yellow primer, they use it on all the Pietenpols now...Sent from my iPadJack TextorOn Jan 12, 2013, at 2:35 PM, helspersew(at)aol.com wrote:> Ken,> > Love that copper idea.......but you have inadvertently revealed at least one your secret colors. Be prepared for imitators.> > Dan Helsper> Puryear, TN> -----Original Message-----
Beautiful work Ken, I'm feeling like a slug...Sent from my iPadJack TextorOn Jan 12, 2013, at 2:12 PM, Ken Bickers wrote:> > Yes, John. Copper sheets. A friend had a couple pieces left over> from a home repair project. He gave them to me, thinking maybe I could> use them on the Pietenpol. I'm not sure the thickness, but will be> happy to measure. I'd guess around 0.040. The pieces are attached> with machine screws.> > On the rear panel, each group of instruments is attached to a separate> copper sheet, allowing the instruments to be removed as clusters. On> the aft right hand sheet will later be installed a com and> transponder, which I'll need because the plane is based under a Class> B veil (and because I'll be installing an engine-driven electrical> system).> > On the front panel, the copper pieces are purely decorative, though> the middle one serves as a door to a glove box. They are also> installed with machine screws.> > On Sat, Jan 12, 2013 at 12:17 PM, John Francis wrote:>> >> Awesome Ken! Is that copper veneer? If so, did you glue it down as well?>> >> John>> >> -------->> John Francis>> >> >> >> >> Read this topic online here:>> >> http://forums.matronics.com/viewtopic.p ... 112#392112> > > > ________________________________________________________________________________
We're under the modeC veil at an uncontrolled, but very busy, airport.On Jan 12, 2013, at 2:05 PM, Wayne Bressler wrote:> > Are you based within the Bravo, or inside the Mode C veil?> > Wayne Bressler> Taildraggers, Inc.> www.taildraggersinc.com> > On Jan 12, 2013, at 3:12 PM, Ken Bickers wrote:> >> >> Yes, John. Copper sheets. A friend had a couple pieces left over>> from a home repair project. He gave them to me, thinking maybe I could>> use them on the Pietenpol. I'm not sure the thickness, but will be>> happy to measure. I'd guess around 0.040. The pieces are attached>> with machine screws.>> >> On the rear panel, each group of instruments is attached to a separate>> copper sheet, allowing the instruments to be removed as clusters. On>> the aft right hand sheet will later be installed a com and>> transponder, which I'll need because the plane is based under a Class>> B veil (and because I'll be installing an engine-driven electrical>> system).>> >> On the front panel, the copper pieces are purely decorative, though>> the middle one serves as a door to a glove box. They are also>> installed with machine screws.>> >> On Sat, Jan 12, 2013 at 12:17 PM, John Francis wrote:>>> >>> Awesome Ken! Is that copper veneer? If so, did you glue it down as well?>>> >>> John>>> >>> -------->>> John Francis>>> >>> >>> >>> >>> Read this topic online here:>>> >>> http://forums.matronics.com/viewtopic.p ... 112#392112> > > > ________________________________________________________________________________Subject: Re: Pietenpol-List: Panel coamings
...said the greatest imitator of all time!!GeneOn Jan 12, 2013, at 3:35 PM, helspersew(at)aol.com wrote:> Ken,> > Love that copper idea.......but you have inadvertently revealed at least one your secret colors. Be prepared for imitators.> > Dan Helsper> Puryear, TN> -----Original Message-----
