Pietenpol-List: spar mistake
My 7th grade students made their first big mistake on our Piet project.They cut one of the wing spars =BD=94 too short. Lesson learned-measure manytimes, cut once. Does anyone have any suggestions on how to proceed?Obviously, one expensive option is to purchase a new spar. How bad is theoption to make all the spars =BD=94 too short leading to a wingspan that is 1=94shorter. Will that give us a higher cruise speed (ha, ha).________________________________________________________________________________
RE: Pietenpol-List: spar mistake
Just my opinion, Scott, but the only thing it really affects is theattachment of the wing-tip bow. Make a longer bracket to put the bow in theright place and move on. Gary BootheNX308MB
Re: Pietenpol-List: spar mistake
Original Posted By: Scott Cutler
Scott,I myself would not worry about it. Clipped-wing Piet.Dan HelsperPuryear, TN-----Original Message-----
Scott, I would either do as you suggested -- make all the spars 1/2 inch shorter or, on the tip end of that spar, glue on a 1/2- inch piece to attach to the wing tip. The spars are cut down to 1 inch wide at that point anyway. I believe the glue joint would be about as strong as if the spar were one piece. Any of you engineers out there disagree? C ----- Original Message -----
Pietenpol-List: Re: spar mistake
Tim, the email I have for you is bouncing. If you want the Piet Directoryplease send me your new address to jack(at)textors.com.Thanks,JackJack TextorDes Moines, IA________________________________________________________________________________Subject: Pietenpol-List: Re: spar mistake
Re: Pietenpol-List: Re: spar mistake
.... a good time for your students to learn how to make a scarf joint.Its all about education, right.WF2--------Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 15 Jan 2013 08:02:00 -0600Subject: Re: Pietenpol-List: Re: spar mistake
Ryan just made me look up a word.Pedant`ismn. 1. The office, disposition, or act of a pedant; pedantry. Ahhh... now it's clear.BCRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 15 Jan 2013 11:12:45 -0700Subject: Re: Pietenpol-List: Re: spar mistake
