Pietenpol-List: using inferior anything or cutting corners----just fly
Subject: Pietenpol-List: using inferior anything or cutting corners----just flyalone then> RXD0)[Vantage Partners, LLC]" > Great post Douwe. I think it is fine if you want to cut corners on your hardware,glue, materials, and engine> rebuild IF you are building a ONE seater but if you even think about giving aride you're being pretty arrogant> and irresponsible to use crappy materials or cut any corners in building whateverhomebuilt airplane you're building. > Enough bad things can happen even if you use the best of everything....in clear,perfect VFR weather no less. > > Mike C.> > > > > > > ________________________________________________________________________________
Subject: Pietenpol-List: using inferior anything or cutting corners----just flyalone thenGreat post Douwe. I think it is fine if you want to cut corners on your hardware,glue, materials, and enginerebuild IF you are building a ONE seater but if you even think about giving a rideyou're being pretty arrogantand irresponsible to use crappy materials or cut any corners in building whateverhomebuilt airplane you're building. Enough bad things can happen even if you use the best of everything....in clear,perfect VFR weather no less. Mike C.________________________________________________________________________________
