Wow Rick,I count 7 airplanes it that hanger. Just amazing. The Piet look the best if youask me. Good luck on the engine run. Don't forget to tie the tail down soit won't fall over on its nose. I have seen it happen to the same guy more thanonce. Thorp T-18 without wings attached since you were going to ask anyway.Cheers,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: O-200 prop for sale
Disclaimer: I am not selling this prop and I do not know much about it. In thegarage with the A75 that I bought and which now hangs on my airplane, was a polishedmetal prop that I was not interested in. The family is trying to clearout these items and would like to sell the prop. The only picture I have ofit is attached, and I did a little bit of tracking down of the numbers on itwith McCauley. The clearest number on it is the Type Certificate TC918, whichnarrows it down to 13 groups of propellers under that TC. The number 1A102 isalso visible on it, and according to McCauley that narrows it down to the CessnaA150, L, M, and 150L, M.Of that bunch, the C-150L was the most produced model, so I assume that's whatit fits. In that case, it is probably a 69x48 for the O-200. However, it mayhave been cut down or modified from stock. There is currently one such proplisted on Barnstormers for $850 but I suspect it is in much better condition thanthe one I'm referring to.I have no other information on this prop. Call Tom Campbell, (210)325-9599 inSan Antonio, TX if you need more info.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/p314 ... __________
RE: Pietenpol-List: Re: Prop on
The same guy? ...and I thought I was slow learner... Gary BootheNX308MB-----Original Message-----
