Pietenpol-List: Shielded mag switches...
Original Posted By: "Dale Johnson"
Quick question, and I know this has been covered before...BUT:Should the shield of the shielded wire from the mags to the switches be groundedon BOTH ENDS, or ONLY ONE END; and if one end, WHICH END? Or does it reallymatter?Thanks,Ray KrauseStill working on SkyScoutSent from my iPad________________________________________________________________________________
Re: Pietenpol-List: Shielded mag switches...
Original Posted By: "Ray Krause"
RayGround it at the Mag end only . If yoy ground it at both ends it will set up edy curents and cause more noise.Dale----- Original Message -----
Pietenpol-List: Re: Shielded mag switches...
Original Posted By: jim hyde
Mine are not grounded at the switch either. I clipped off the braid at that endand then used a little heat-shrink tubing to cover that part of the wire. Ihad heard the same thing about the possibility of circular currents. I havenot yet had a chance to operate my handheld in the cockpit to see if the groundingscheme and shielded harness have taken care of ignition noise, but I'll soonfind out.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 28 Apr 2014 14:05:48 -0700 (PDT)
Original Posted By:> ----- Original Message ----- "Ray Krause"
Thanks, Dale. That what I will do. Sure is a great way to get a quick answer.Ray KrauseSent from my iPad> On Apr 28, 2014, at 11:17 AM, "Dale Johnson" wrote:> > > Ray> > Ground it at the Mag end only . If yoy ground it at both ends it will set upedy curents and cause more noise.> > Dale
