Original Posted By: "Pocono John"
One more thing.Any plywood you use for structural components (gussets, etc.) should be eitherAircraft Plywood or Marine Plywood. The glues used to make the plywood need tobe waterproof. Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Rib Dimensions Drawing
Pietenpol-List: Re: Rib Dimensions Drawing
Original Posted By: "JSeitz"
Gene,I'm about five hours north by car, 2.5 by plane. Could I help?Ray KrauseColusa, CASent from my iPad> On Jul 19, 2014, at 5:07 AM, Gene Rambo wrote:> > > Is anyone on this list at or near Bakersfield CA???> > Gene> >> On Jul 19, 2014, at 7:30 AM, "Andre B. Charvet" wrote:>> >> >> I may have a set of piston pins Gene.>> Ben>> >> Gene Rambo wrote:>>> >>> For what it's worth guys, I'm going for the engine. I'm over the model A. Hopeno one else needs the Continental too...>>> >>> Anyone want a boat anchor??>>> >>> Gene>>> >>>> On Jul 18, 2014, at 4:30 PM, John Hofmann wrote:>>>> >>>> >>>> If anyone is interested, I got this through the Cub Club. I know nothing otherthan what is below.>>>> >>>> Continental A65-8 engine disassembled. Tapered shaft ground .010 under withprop. hub. Zero time on .015 over cylinders. Cylinders are complete with newA75 pistons. Rockers arms overhauled. Engine is complete but will need .859 pistonpins. Extra set of push rods, rocker arms, cam followers, plungers and carb.$1500, Tom Arnold, 661-623-1611, email: earnold(at)bak.rr.com>>>> >>>> >>>> Best,>>>> -john->>>> >>>> John Hofmann>>>> Vice-President, IT and Production>>>> The Rees Group, Inc.>>>> 2424 American Lane>>>> Madison, WI 53704>>>> Phone: 608.443.2468 ext 150>>>> Fax: 608.443.2474>>>> Email: jhofmann(at)reesgroupinc.com> > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Rib Dimensions Drawing
I'm about an hour and a quarter from Bakersfield by car. Maybe longer by Pietenpol; )Mike GroahTulare CA414MVSent from my iPhone> On Jul 19, 2014, at 5:07 AM, Gene Rambo wrote:> > > Is anyone on this list at or near Bakersfield CA???> > Gene> >> On Jul 19, 2014, at 7:30 AM, "Andre B. Charvet" wrote:>> >> >> I may have a set of piston pins Gene.>> Ben>> >> Gene Rambo wrote:>>> >>> For what it's worth guys, I'm going for the engine. I'm over the model A. Hopeno one else needs the Continental too...>>> >>> Anyone want a boat anchor??>>> >>> Gene>>> >>>> On Jul 18, 2014, at 4:30 PM, John Hofmann wrote:>>>> >>>> >>>> If anyone is interested, I got this through the Cub Club. I know nothing otherthan what is below.>>>> >>>> Continental A65-8 engine disassembled. Tapered shaft ground .010 under withprop. hub. Zero time on .015 over cylinders. Cylinders are complete with newA75 pistons. Rockers arms overhauled. Engine is complete but will need .859 pistonpins. Extra set of push rods, rocker arms, cam followers, plungers and carb.$1500, Tom Arnold, 661-623-1611, email: earnold(at)bak.rr.com>>>> >>>> >>>> Best,>>>> -john->>>> >>>> John Hofmann>>>> Vice-President, IT and Production>>>> The Rees Group, Inc.>>>> 2424 American Lane>>>> Madison, WI 53704>>>> Phone: 608.443.2468 ext 150>>>> Fax: 608.443.2474>>>> Email: jhofmann(at)reesgroupinc.com> > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Rib Dimensions Drawing
I can relate. When I routed my spars, after I finished I discovered that despitemeasuring a hundred times, I had left the "unrouted" areas where the strutsattach in the wrong areas. I went ahead and routed the entire spar (except centersection, of course) and made inserts that matched the curve of the routededge and fit exactly into the spar. I glued them into the proper locations,you can't tell the difference and just as strong. Oops....GeneOn Jul 24, 2014, at 10:29 AM, "aerocarjake" wrote:> > Some data: The spars were 12 1/2 pounds each - before routing - and 8 1/2 poundsafterwords.... FOUR pounds lighter EACH spar. Since I routed "too deep"I figure to save perhaps THREE pounds per spar with the final ones.> > Yes, I considered what repairs I could do to salvage the spars, but in the enddecided to simply "do what's right" and make new good ones.> > If anyone wants to stop by Seattle for some free "cap strip or fuselage" rawmaterial, they are more than welcome to them. (I have a welded steel fuselageand the rest of the wings are essentially complete so using them as hangar/wallart is my current best option...!)> > In the end I got a REALLY nice new router out of this whole experience. It'sMUCH quieter and variable speed...
> > --------> Jake Schultz - curator,> Newport Way Air Museum (OK, it's just my home)> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 282#427282> > > > > > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Rib Dimensions Drawing
Original Posted By: Dan Yocum
JSeitz wrote:> I have the same situation. The response I got on the Facebook group was to notworry about it. The rudder versus the vertical fin + fuselage is also a bitoff (I want to say half an inch iirc). I used the listed dimensions and then tookthe extra 1/8 inch off the back. The place I am still slightly contemplativeis the nose of the rib (I plan on further editing). What did you do for yournose on the drawing?I've been away, so I have not tackled the nose yet. To add to Earl's comment abouthandrails, I had taken my Hatz Classic leading edge profile to Lowe's andfound a railing that was almost an exact match.certainly close enough I coulduse it.--------JohnRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
