Yes, all your tail surfaces should be rib stitched and use the closer spacing asit isn't most definitely in the prop washDouweSent from my iPhone________________________________________________________________________________
Pietenpol-List: Rub stitching stab
Re: Pietenpol-List: Tail wheel angle?
Thanks, Douwe, good advice, will do. I am about to order my materials from StewartSystems. Do you know how much tape and thread you used?Thanks, RAYSent from my iPad> On Aug 20, 2014, at 7:19 AM, Douwe wrote:> > > Yes, all your tail surfaces should be rib stitched and use the closer spacingas it isn't most definitely in the prop wash> > Douwe> > Sent from my iPhone> > > > ________________________________________________________________________________Date: Wed, 20 Aug 2014 21:16:46 -0600Subject: Re: Pietenpol-List: Tail wheel angle?
