I'm building the 3 piece wing and can't figure out the rib placement. I've positioned the ribs according to the original 29 ft wing plan, but when I refer to the 3 piece wing supplement, I notice there seems to be a rib located 8 1/4" from the butt rib on the wing (next to the center section). That leaves the gap to the next rib approximately 5". Am I missing something? Should I reposition the next rib to split the difference?Tim WhiteSpringfield Ohio________________________________________________________________________________
Pietenpol-List: Rib Spacing, 3 Piece Wing
RE: Pietenpol-List: Rib Spacing, 3 Piece Wing
Tim,I built mine as you describe. Doesn=99t even show....Gary BootheNX308MB-----Original Message-----
Re: Pietenpol-List: Rib Spacing, 3 Piece Wing
Original Posted By: Jack
Beautiful! Looks like living room furniture or art work!Ray KrauseJust a farmer cobbling together a SkyScoutSent from my iPad> On May 29, 2015, at 4:51 AM, Jack wrote:> > Getting a little tired of sanding, varnish, sanding. A few more coats to go!> > > > > > Sent from my iPad> Jack Textor> > > > ________________________________________________________________________________Subject: Re: Pietenpol-List: Rib Spacing, 3 Piece Wing
Speaking of Sherpas and climbing Mount Everest, there are some good documentariesabout that on Netflix
--------KLNCA65-8N2308CSlick 4330'sAN HardwareAirframe 755TTW72CK-42 SensenichStandard Factory GN-1Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sat, 30 May 2015 07:16:30 -0400Subject: Re: Pietenpol-List: Rib Spacing, 3 Piece Wing
Agreed Chuck, with one note. I did what you described. My mistake was trying to approximate the connection location. Should have the tab connections installed...Sent from my iPadJack Textor> On May 30, 2015, at 6:16 AM, "Charles N. Campbell" wrote:> > OK, I agree with Jack except on one fine point. I put my ribs in loose and spaced them approximately where they were supposed to go. I then used mason's cord to run where the drag and anti-drag wires were to go and spaced the ribs so that they cleared the cords. I glued the ribs in place at this point, took the cords out and then put in the compression struts, and then the drag wires -- minor difference. Chuck> >> On Fri, May 29, 2015 at 12:58 PM, Jack wrote:>> >> Tim be sure to not secure ribs before you have the drag wires in. I didn't and it was a pain altering the ribs to clear the wires.>> >> Sent from my iPad>> Jack Textor>> >> > On May 29, 2015, at 8:34 AM, Tim White wrote:>> >>> >>> > I'm building the 3 piece wing and can't figure out the rib placement. I've positioned the ribs according to the original 29 ft wing plan, but when I refer to the 3 piece wing supplement, I notice there seems to be a rib located 8 1/4" from the butt rib on the wing (next to the center section). That leaves the gap to the next rib approximately 5". Am I missing something? Should I reposition the next rib to split the difference?>> >>> > Tim White>> > Springfield Ohio>> >>> >>> >>> >>> >> >> =>> br> enpol-List" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List>> ==========>> FORUMS ->> _blank">http://forums.matronics.com>> ==========>> b Site ->> -Matt Dralle, List Admin.>> target="_blank">http://www.matronics.com/contribution>> ==========> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> ________________________________________________________________________________
