Pietenpol-List: Toolstock '16
jarheadpilot82 wrote:> Steve,> > bad elf has a GPS with it, and I do not believe the Stratux does.> > Terry, Stratux definitely support GPS - I got my GPS for Stratux for $14.00Still no OUT, but you cant beat getting IN for around $120. Since I was nevergoing to put in a Xponder, ADS-B IN is all I will ever want or need for my Pietenpol.Gee no flying in A B or C airspace...bummer.--------Bob 'Early Builder' DewenterDayton OHRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Toolstock '16
Pietenpol-List: Re: Toolstock '16
Original Posted By: "tools"
Reaching out to 'Tools' - Are you having toolstock this year? if so what are thedates?Bob--------Bob 'Early Builder' DewenterDayton OHRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Toolstock '16
Sorry man, not this year!Our hostess just had an operation and is recovering. House is nearly done withmajor renovations. I wasn't able to get a single weekend off the entire month.And with trying to get two airplanes airworthy here in wisconsin I haven'tbeen able to get down there to clean, restock and have thing ready. Stage is set for next year though! I'll probably make it every two years anyway.Might start hosting something up here in wi on the off years.Not Piet related, but the list hasn't had any pics in a while, so... Two morecoats of varnish, install control cables and the fuse is ready to cover.ToolsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/imag ... ___Subject: Pietenpol-List: Re: Toolstock '16
Dagnabbit Mike!Your punishing me for not making it last year....--------Bob 'Early Builder' DewenterDayton OHRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Toolstock '16
Not true! More than welcome to come up here some weekend. No saw mill, but haveabout everything else, including planes I can actually give rides in!ToolsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Toolstock '16
Tools,The Chief? Nice work, whichever project it is>--------Semper Fi,Terry HandAthens, GARead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Toolstock '16
Pietenpol-List: Re: ADS-B
Thanks.Yep. That's the chief. Making progress on the duster too. Fuse longeron repaired.Landing gear mounts go on next. Rebuild the gear leg and more or lessstart putting her back together. ToolsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: ADS-B
Original Posted By: woodflier
This thread is a bit off topic, but I wanted to pass along my experience with gettingthe Stratux ADS-B traffic to display within Avare on my Android tablet(finally had a reason to buy one!)Avare requires an add-on app for ADS-B. I needed to configure the add on app touse WIFI (not Bluetooth) and to use port 4000 (not the default of somethinglike 4221).>From inside my house I was getting traffic alerts (so far only commercial airliners)showing up about 30 NM away. Pretty cool and fun to watch.also, my digital receiver antenna(s) are fully retracted.--------Bob 'Early Builder' DewenterDayton OHRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 20 Jan 2016 10:51:50 -0500
Re: Pietenpol-List: Re: ADS-B
Subject: Re: Pietenpol-List: Re: ADS-B
Marcus,With Avare you actually need two apps. The Avare mapping program and the Avare I/O add-on connection app. Start up the I/O app, select WiFi connection then enter 4000 for the port. Next click on listen. If all is right with the world you should immediately see your are connected then a stream of date being displayed. Once you have this, then launch Avare. One more thing to be aware of with Stratux is if you have multiple navigation programs on your device, make sure you completely close down the app before switching to another app. This is especially true with the I/O app Avare uses. The reason for this is once your are connected and listening to Stratux on port 4000, that port is locked with a handshake to the Stratux. That handshake needs to be shut down before you can re-link with another app on the same port.Regards,Rick SchreiberValparaiso, INOn 1/20/2016 11:14 AM, Marcus Zechini wrote:>> Thanks! Had to get Avare, as Garmin Pilot has proprietary interface. I > have the WiFi add on, but still no joy. Will try port change.>> On Jan 20, 2016 9:52 AM, "bdewenter" > wrote:>> >>> This thread is a bit off topic, but I wanted to pass along my> experience with getting the Stratux ADS-B traffic to display> within Avare on my Android tablet (finally had a reason to buy one!)>> Avare requires an add-on app for ADS-B. I needed to configure the> add on app to use WIFI (not Bluetooth) and to use port 4000 (not> the default of something like 4221).>> >From inside my house I was getting traffic alerts (so far only> commercial airliners) showing up about 30 NM away. Pretty cool and> fun to watch.> also, my digital receiver antenna(s) are fully retracted.>> --------> Bob 'Early Builder' Dewenter> Dayton OH>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... 129#452129>>> ==========> br> fts!)> r> > w.buildersbooks.com" rel="noreferrer"> target="_blank">www.buildersbooks.com> rel="noreferrer" target="_blank">http://www.matronics.com/contribution> -Matt Dralle, List Admin.> ==========> br> enpol-List" rel="noreferrer"> target="_blank">http://www.matronics.com/Navigator?Pietenpol-List> ==========> FORUMS -> eferrer" target="_blank">http://forums.matronics.com> ==========> b Site -> -Matt Dralle, List Admin.> rel="noreferrer" target="_blank">http://www.matronics.com/contribution> ==========>>________________________________________________________________________________Date: Wed, 20 Jan 2016 13:01:22 -0500Subject: Re: Pietenpol-List: Re: ADS-B
I was aware you were at VPZ, but forgot. The staff here made sure I knew that they had talked to you.RickOn 1/20/2016 12:01 PM, Marcus Zechini wrote:>> Thanks! While I don't use in the Piet, the Piet did spend a night in > Valparaiso hangar last summer on way to Brodhead!>> On Jan 20, 2016 12:58 PM, "Richard Schreiber" > wrote:>> Marcus,> With Avare you actually need two apps. The Avare mapping program> and the Avare I/O add-on connection app. Start up the I/O app,> select WiFi connection then enter 4000 for the port. Next click on> listen. If all is right with the world you should immediately see> your are connected then a stream of date being displayed. Once you> have this, then launch Avare. One more thing to be aware of with> Stratux is if you have multiple navigation programs on your> device, make sure you completely close down the app before> switching to another app. This is especially true with the I/O app> Avare uses. The reason for this is once your are connected and> listening to Stratux on port 4000, that port is locked with a> handshake to the Stratux. That handshake needs to be shut down> before you can re-link with another app on the same port.>> Regards,> Rick Schreiber> Valparaiso, IN>> On 1/20/2016 11:14 AM, Marcus Zechini wrote:>>>> Thanks! Had to get Avare, as Garmin Pilot has proprietary>> interface. I have the WiFi add on, but still no joy. Will try>> port change.>>>> On Jan 20, 2016 9:52 AM, "bdewenter" > > wrote:>>>> >>>>> This thread is a bit off topic, but I wanted to pass along my>> experience with getting the Stratux ADS-B traffic to display>> within Avare on my Android tablet (finally had a reason to>> buy one!)>>>> Avare requires an add-on app for ADS-B. I needed to>> configure the add on app to use WIFI (not Bluetooth) and to>> use port 4000 (not the default of something like 4221).>>>> >From inside my house I was getting traffic alerts (so far>> only commercial airliners) showing up about 30 NM away. >> Pretty cool and fun to watch.>> also, my digital receiver antenna(s) are fully retracted.>>>> -------->> Bob 'Early Builder' Dewenter>> Dayton OH>>>>>>>>>> Read this topic online here:>>>> http://forums.matronics.com/viewtopic.p ... 129#452129>>>>>>>>>>>>>>>> ==========>> br> fts!)>> r> > w.buildersbooks.com ">> rel="noreferrer" target="_blank">www.buildersbooks.com>> >> rel="noreferrer">> target="_blank">http://www.matronics.com/contribution>> -Matt Dralle, List Admin.>> ==========>> br> enpol-List" rel="noreferrer">> target="_blank">http://www.matronics.com/Navigator?Pietenpol-List>> ==========>> FORUMS ->> eferrer" target="_blank">http://forums.matronics.com>> ==========>> b Site ->> -Matt Dralle, List Admin.>> rel="noreferrer">> target="_blank">http://www.matronics.com/contribution>> ==========>>>>>>>________________________________________________________________________________Date: Wed, 20 Jan 2016 13:43:44 -0500Subject: Re: Pietenpol-List: Re: ADS-B
