Pietenpol-List: Angle of Attack t which the Pietenpol wing will stall
Original Posted By: Donald A Mosher
Fortune Cookie--------KLNCA65-8N2308CSlick 4330'sAN HardwareAirframe 755TTW72CK-42 SensenichStandard Factory GN-1Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/fort ... ______Date: Sun, 1 May 2016 14:56:31 -0500Subject: Pietenpol-List: Angle of Attack t which the Pietenpol wing will stall
Re: Pietenpol-List: Angle of Attack t which the Pietenpol wing will stall
Subject: Re: Pietenpol-List: Angle of Attack t which the Pietenpol wing will stall
RE: Pietenpol-List: Angle of Attack t which the Pietenpol wing will stall
Hi Doc,My plans are dated 3-26-34 and page 6 shows the front cabane strut length as 21 =C2=BC=9D and the rear cabane length as 20 =C2=BC=9D . It also says =9CNote: short rear strut gives wing 2 deg. Incidence=9DGreg Cardinal
Mine too. Also, on page 20 of the F&G, 1932, there's adrawing, upper left column, that show's the same thing.And states this gives 2=C2=B0 incidence.Clif ----- Original Message -----
Pietenpol-List: Re: Angle of Attack t which the Pietenpol wing will stall
the drawing does state that the wing struts are the same length but thecabane struts are shown as different lengths to make the 2 degrees incidence. while it is a little confusing and not the way it would be drawn today- it isthere--------Earl BrownI may not have gone where I intended to go, but I think I have ended up where Iintended to be.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/stru ... ___Subject: Pietenpol-List: Re: Angle of Attack t which the Pietenpol wing will stall
