All, I have started building the fuselage and originally planned(because I assumed it was obvious) to steam bend the longerons. I could not find anything in the book that came with the plans about steam bending the longerons just the cap strips. After I built the fuselage side jig I found that the bottom longeron bent into place without issue. Even though I could glue it like this in my mind there would always be tension in the truss as the bottom longeron tried to unbend back to being straight. I know the epoxy will hold I am just worried that after years(decades) that the epoxy could fail. I was also not sure if there were any problems with the fuselage being under that tension and having a hard landing. Are there any thoughts on whether Mr. Pietenpol originally steam bent the longerons or just bent them into the form dry?
Sean
Steam Bending Longerons
- Clay Hammond
Re: Steam Bending Longerons
Tangential to your question, but great way to steam bend here from 3:15 mark onward:
https://www.youtube.com/watch?v=7JFePos8RQQ
Sean, this really isn't an issue, as far as i know, all of Bernards planes were formed dry- the bend is not that great to have to steam the longeron. There is not enough tension there to cause any problems (long or short term) and the side sheeting also holds it in that position.
Not a problem to keep you up at night! Put the longerons in the jig and get gluing!
Earl
Earl
builderwannabe
Gents, thanks for the info, it helps to bounce ideas off of others, I’ll start slathering on the T-88 tomorrow.
Sean
Sean
To further put your mind at ease...
Years ago I broke my lower longerons right there in the curve. I scarfed new longerons on right there using the normal 15:1 taper, but without scarf plates and dry bent them right back into place.
The joints are readily visible and easy to inspect. Despite the tension and years since, even in very hot weather, there has been no movement in the scarf joints whatsoever. I used T-88.
Tools
Tools
