Clamping pressure
zippythehog
Clamping pressure
Post by zippythehog »
How can I measure clamping pressure for gluing gussets? AC43.13 recommends 125-150#/sq” for softwood. I couldn’t find any other recommendations for T88. I don’t want to use any clamp and hope for the best.
LarryM
Re: Clamping pressure
Post by LarryM »
Bonding pressure is mentioned in the white oak/teak section.
T-88_TDS.pdf
(25.14 KiB) Downloaded 97 times
zippythehog
Thank you.
How does one determine clamping pressure per square inch?
LarryM
Post by LarryM »
"minimal pressure -- just enough to ensure contact"
The pressure you quote is for resorcinol glue and doesn't apply to epoxy. Contact pressure is all that's required. Read the T88 instructions.
zippythehog
Thanks Larry and Richard. I see that now.
