Carbon Fiber Floorboards
Anyone ever use carbon fiber panels for the floorboards as opposed to wood?
Re: Carbon Fiber Floorboards
The Piet doesn't have floorboards, as such. Your feet are on the bottom 1/4" plywood. Which is a structural member of the fuselage truss. If you plan on using carbon fiber panels, you need to do some load calculations.
Oh yes, that makes sense...and sounds complicated...
