Subject: Pietenpol-List: Pushrods.>Has anyone figured out how to install push rods on the controlls? Can it>be done. >>Steve>>________________________________________________________________________________
Original Posted By: claude
Has anyone figured out how to install push rods on the controlls? Can itbe done. Steve________________________________________________________________________________
Pietenpol-List: Re: Pushrods.
Original Posted By: Greg Yotz
--->Has anyone figured out how to install push rods on the controlls? Can it>be done. >>SteveWhy?Mike B Piet N687MB ( Mr Sam )________________________________________________________________________________
DON'T MESS WITH SUCCESS!-----Original Message-----
I installed a push/pull tube from the control stick to the elevatorwalking beam.No compelling reason to do so other than "I wanted to". Found out that rodend bearings are a LOT more expensive than pulleys also.If you do this, be careful not to change the control geometry.Greg>>> 09/12 3:14 PM >>>Has anyone figured out how to install push rods on the controlls? Can itbe done.Steve________________________________________________________________________________
