Had some problems with the plane getting away from me on landing. And found thetailwheel cables not tight. I know this was talked about earlier. Should thecables be tight to the springs?I'm flying a rudder bar as opposed to pedals. Trying to find where the weakspot is. (hopefully it's not me!)Any tips on landing a tailwheel with tall and narrow gear? If I break a wing,the flying season is over.thanks,walt________________________________________________________________________________
Pietenpol-List: ground looping and lose tailwheel cables
Re: Pietenpol-List: ground looping and lose tailwheel cables
Yes, the cables hould be reasonably tight although what you usually see withloose cables is shimmy. The only advice I'd give is KEEP THE STICK BACK . .. HARD.If you manage to break a high-wing on landing we are going to line up andtake turns giving you a swift kick in the rear.Gene
----- Original Message -----
Original Posted By: Mike
Subject: Re: Pietenpol-List: ground looping and lose tailwheel cables
Original Posted By: "Mike"
what if one put two independent rudder bars in place of the single bar,Sorta like hinged in the middle, thus allowing feet pressure to take up anyslack. ???????----- Original Message -----
Re: Pietenpol-List: Wing tank level sight guage....
I bought a Stearman guage from ACS and cut it down to fit my tank. I had tore-tap the plug and shorten the wire to the cork but it works fine.Dick----- Original Message -----
