Pietenpol-List: Aircamper rudder control
Re: Pietenpol-List: Aircamper rudder control
Subject: Re: Pietenpol-List: Aircamper rudder controlCarl,I suggest you just rig the rudder bar per plans, and run the rudder cables down low near the floor under the seat. Acording to AC 43.13 you can use hardwood (not pulleys) as a fairlead, if the deflection is less than 7 degrees.Chuck G.________________________________________________________________________________
