Pietenpol-List: Hello from sunny South Africa
Hello Everyone !I am so glad I have discovered this fantastic forum ! Lots to learn and even moreinsperation !My project is progressing well, I still need to finish the cowl, control cableinstallation, redo intrument panel and then cover. The powerplant is a Ford 2Lcrossflow motor with a reduction drive, Yes, I know not an "A" but there areno A's to be found down here ! It has the longer metal fuselage. The registration is ZU-BDZ and will share a hanger once complete with my other"toys", ZU-AVB a Streak Shadow (Jabiru powered) and ZU-AMV a KR2S (VW powered).I will be creating a web-page for my baby soon, need to take some photos first.Have a great day and safe flying,RudiRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Hello from sunny South Africa
Original Posted By: "Rudi_Venter"
Rudi,Someone else is in So. Africa with a Piete, 0-235 engine, can't recall name, posted pics and discussion of first flight last year. If he's out there in internet land, post up.Gordon----- Original Message -----
Pietenpol-List: Re: Hello from sunny South Africa
Subject: Re: Pietenpol-List: ferry pilot for Tcraft neededWhen does it need to go? Tom Travis________________________________________________________________________________Subject: Pietenpol-List: Re: Hello from sunny South Africa
Original Posted By: "Bill Princell"
gbowen(at)ptialaska.net wrote:> Rudi,> Someone else is in So. Africa with a Piete, 0-235 engine, can't recall name,> posted pics and discussion of first flight last year. If he's out there in > internet land, post up.> Gordon> > ---Hi Gordon,Interesting, there is a Piet at my local flying field with a 0-235, it is quitenew and did change hands recently so it could be the same one !Will try and get some more background on it.Regards,RudiRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 27 Sep 2006 23:17:39 -0500
Subject: Re: Pietenpol-List: Hello from sunny South AfricaIn a message dated 9/27/2006 1:29:09 PM Central Standard Time, gbowen(at)ptialaska.net writes:Rudi,Someone else is in So. Africa with a Piete, 0-235 engine, can't recall name, posted pics and discussion of first flight last year. If he's out there in internet land, post up.GordonWe haven't heard much from this fellow, but here is the info I have in my archives:Chuck G.NX770CGNorman Stapelberg s s r f 55 norshel(at)mweb.co.za South Africa ZS-VJA FASI Just thought I'd pop in a quick note my baby flew Sunday for the first time in two years. Got some small mods to do,1. prop to be repitched (only getting 2000Rpm static). Lycoming 0-2352. Battery to be moved C of G tad to far fwd.3. A.S.I to be calibratedRegards,Norman StapelbergZS-VJA (115Hrs)South Africa FASIFirst Flight this year - 2/13/04________________________________________________________________________________
Re: Pietenpol-List: Repairing Wood Fuselage Built with T-88
Original Posted By: "Bill Weir"
Subject: Re: Pietenpol-List: Repairing Wood Fuselage Built with T-88In a message dated 9/27/2006 11:19:39 PM Central Standard Time, weprincell(at)gmail.com writes:Anyone out there have a good method for removing plywood bonded with T-88 to from the side and bottom of a 25yr old Pietenpol fuselage built with Sitka spruce? A landing accident splintered the plywood and broke the lower longeronin two places near the forward landing gear attachment bracket.Bill Princell -Bill,I've never tried it, but I hear that a Router with a flat cut bit can remove the plywood & adhesive, and leave the longeron untouched. Naturally, you should practice on some scrap. Use at least a 12:1 scarf joint on the longeron- the method is called out in the AC 43.13.Chuck G.NX770CG________________________________________________________________________________
[quote="billweir(at)lon.imag.net"]Hi Rudy, Which engine are you using? I know what is in s. Africa would not be here inCanada and vice versa. Is it the engine that started at 900 something and thengrew and went crossflow? Are you using a reduction system? The callout formy own project is the current all aluminum twin cam 2L. Bill Weir > Hi Bill,I am not sure about the history of the engine, I do know there used to be a 1600ccas well. It is a basic 4 cylinder inline engine. It could well be that itwas developed from a much smaller engine over the years.Yes, I am using a reduction drive, it is a 2.5:1 belt reduction.Happy building,Regards,Rudi--------ZU-AMV ZU-AVB ZU-BDZ ZS6DX/V51VERead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Hello from sunny South Africa
