Pietenpol-List: IGNITION SHIELDING Needed on A-65
After installing a cowl mounted antenna (RAMI AV-534) for my hand held radio Ihave ignition noise in the radio. Is the IGNITION SHIELDING BRAID as sold by Aircraft Spruce effective? http://www.aircraftspruce.com/catalog/e ... dbraid.php Pictures attached of the offending ignition. :)--------Dan PlettRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/sam_ ... __________
RE: Pietenpol-List: carb rebuilder?
Don Swords of Don's Dream Machines did ours for the 6 Big Piets and suppliedthe cores. He does seminars at Osh and SnF on small Continentals and holdsseveral STC's for them. His number is 770-412-8885. We used UPS forshipping.Barry Davis-----Original Message-----
Original Posted By:> bed(at)mindspring.com
Douwe=2C I have rebuilt dozens=2C if not hundreds of these things. Do it yourself=2C it really is a no-brainer. It is all remove and replace=2C no adjustments. The rebuild kits are not expensive (or they didn't use to be). Just disassemble and clean=2C reassemble with new jets and gaskets and you are there. the shaft bushings are the only parts that wear. Ifr you replace the shaft bushing=2C you need a ream for that=2C but it is the most challenging (not) part of the procedure.Gene
Pietenpol-List: Metallurgists opinions please
Pietenpol-List: Re: IGNITION SHIELDING Needed on A-65
My wife and I had our dog with us at Brodhead last year, and nobody said anythingat all about it, and nobody seemed to mind. In fact, he got a lot of headscratches and attention, which he greatly appreciated. We kept him leashed andpicked up after him, and we had no problem at all with him there.Billy McCaskillUrbana, ILLooking forward to Brodhead again this year, but this time I won't have my wifeor the dog with me...--------Billy McCaskillUrbana, ILtailfeathers almost doneRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: IGNITION SHIELDING Needed on A-65
Original Posted By: "Dan P"
Try a location as faraway from the engine as possible with the antenna.Pieti LowellRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: IGNITION SHIELDING Needed on A-65
This antenna needs a ground plane. There aren't any locations that are of a significantdistance from the engine.--------Dan PlettRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 20 Jul 2010 21:34:22 -0400
Re: Pietenpol-List: Re: IGNITION SHIELDING Needed on A-65
Dan,For what it's worth, I'd buy some shielding and give that a try. I put my antenna in the same location on N502R and had wonderful results. Over 50 miles on a handheld while I was at 500 feet AGL. I have used the shielding on 2 strokes with very good results.Gene in Beautiful (but HOT) Tennessee--------------------------------------------------
Dan,One more thing. Make sure your ground wire has good contact with your cowling.Gene--------------------------------------------------
Do you have access to the bell crank for your elevator?I was able to fit a large sheet of light aluminum behind the rear seat and install my antenna out the bottom. Works great.On Jul 20, 2010, at 8:34 PM, Jeff Boatright wrote:> >>> Yeah, but still, you might try it somewhere else and see if it > works. We moved our antenna to the cut-out in the rear of our wing > center section, and it works quite well, no shielding and no > interference. Good luck!>>>>> This antenna needs a ground plane. There aren't any locations >> that are of a significant distance from the engine.>>>> -------->> Dan Plett>>> -- >> Jeff Boatright> "Now let's think about this...">>________________________________________________________________________________Subject: Pietenpol-List: Re: IGNITION SHIELDING Needed on A-65
Pietenpol-List: Re: Crash - Long Post
Kevin,Welcome to my club.Just as I turned the corner after landing,I spotted you taking that final leftturn at 28 ft over my head, I stopped and whipped out my camera , snapped a perfectshot through my cabanes just to the left of the Ford radiator, you wereabout 10 Ft off the turf, with wheel snugged up under like a trick pilot showingoff , and as you administered a perfect, lame duck landing, I proudly loweredmy surprise shot of the day to my lap, and to my astonishment the two camerabatteries had sped to my lap without my knowledge just pry or to the speedycamera work.Sorry KevinBy the way, I see you got a few new drain holes at the trailing edge of the wing,that is the good news.Pieti LowellRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sun, 25 Jul 2010 19:00:29 -0700 (PDT)
Re: Pietenpol-List: Crash - Long Post
Subject: Re: Pietenpol-List: Crash - Long Post
> > > Don Swords of Don's Dream Machines did ours for the 6 Big Piets and supplied> the cores. He does seminars at Osh and SnF on small Continentals and holds> several STC's for them. His number is 770-412-8885. We used UPS for> shipping.> Barry Davis> > -----Original Message-----
