Pietenpol-List: Virginia Pietenpols
Re: Pietenpol-List: New Builder just starting
Hello everyone, my name is Mike Rich from the Dallas Tx. area. A little about me. I have researched for the past two years many different aircraft that would be a good build starting with a Piet,and ending with a Piet. I've been in model aviation for 25 years winning some scale contest and have been around full scale aviation since I was a boy with my father and brother. They kept nagging me,"When are you going to get your license and start flying for real" ? Well I finally did, but there's still something missing. I'm not building anything and it's driving me nuts!! So I joined the EAA,BPA ect. and was told this was the place to get advice if I want to build a Pietenpol Air Camper. Everyone in the Piet community has been very nice and down to earth...I love it. I feel I'm finally with the right group of aviators. I have thus far built a mockup from "Flying and Glider" to see how I would fit, bought all the Benglis books ect.So with that said, I need to order plans now. I'm 6'3" at 240 lbs. and I know I will need the longest fuse/ supplemental plans but I'm not sure about the rest. Do I order the whole shabang or just parts of it? Please advise,thanks.st" target=_blank>http://www.matronics.com/Navigator?Piet ... ___Subject: Re: Pietenpol-List: New Builder just starting
Original Posted By: "Fun2av8"
Jim, I'm just down the road from you in Lexington, VA. I'll probably fly my Piet up to Culpeper later in the spring to check on Gene Rambo's progress with his Piet. Hope to meet you and see your airplane. Matt PaxtonNX629MLsubject: Pietenpol-List: Re: satellite tracking devices
Original Posted By: V Groah
Hey Vic, thanks for the advice. I'm suppose to be getting some info in from Bill Rewey as well, any day now on how to tweak the fuselage ect. I've seen your plane on W.C. Piet, outstanding job good routing work. I'm still new to all of this but wouldn't any mods like wider,longer,ect. just add more weight? I'm intrested in makeing some changes as long as I'm not adding a lot to the wing load. The Piet doesn't have a lot to play with. Or am I totally off base?I really like the door idea.Thanks,Mike ----- Original Message -----
Original Posted By:> V Groah
Hi mike ,I made my fuse 26 in wide I weigh 200 and I am glad that I did. I also put a door on the right side, it makes ingress a lot easier and to work on the inside.. I have the long fuse and my weight is 825 with a corvair and with the 36 in center section I hold 20 gallons of fuel. Cheers, gardiner mason .Sent from my iPadOn Apr 3, 2013, at 6:07 PM, "Mike Rich" wrote:> Hey Vic, thanks for the advice. I'm suppose to be getting some info in from Bill Rewey as well, any day now on how to tweak the fuselage ect. I've seen your plane on W.C. Piet, outstanding job good routing work. I'm still new to all of this but wouldn't any mods like wider,longer,ect. just add more weight? I'm intrested in makeing some changes as long as I'm not adding a lot to the wing load. The Piet doesn't have a lot to play with. Or am I totally off base?> I really like the door idea.> > Thanks,> Mike> ----- Original Message -----
Re: Pietenpol-List: West coast Pieter's
Thanks, the plane still looks good, but I don't look the same!RaySent from my iPadOn Apr 3, 2013, at 11:08 AM, "Gary Boothe" wrote:> It was taken 4 yrs ago! I=99ll bet your Waiex looks exactly the same, thoughand that=99s what really matters!> > Gary Boothe> NX308MB>
Pietenpol-List: Re: Virginia Pietenpols
Matt, Looking forward to meeting you in the Spring. I spoke briefly with Gene (Iknow him from the Flying Circus). He is planning on going to Brodhead in hisPiet (have you seen the pix on FaceBook?). I'm just a couple of hangar rowsover from his at Culpeper (KCJR).I also heard from Zeke Zechini who keeps his Piet at White Post (3VA7) which isjust about an hour NW of Culpeper.Anyone else got a Piet in the local area (VA, MD, WVA, DE, NC, PA)It would be loads of fun to get together and go get a $100 hamburger somewhere.Has anyone formed a local Piet Owners group?Jim--------Jim McWhorterN687MB (New Owner)Culpeper, VA KCJRRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Re: Virginia Pietenpols
I'm a little further from Culpeper than Matt, at Smith Mountain Lake (W91).I've flown my Piet to CJR before, to help Gene work on his. It's about a2-1/2 hour trip.I'm planning on making the trip to Brodhead this summer.Jack PhillipsNX899JPSmith Mountain Lake, Virginia-----Original Message-----
Re: Pietenpol-List: Re: Virginia Pietenpols
Original Posted By: BRETT PHILLIPS
Am trying to visualize how this works, so the white metal arm is free to pivotup and back down with the axel and still prevents rotation under braking? I assumewe only need 2-3 inches of travel for the axel?Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 8 Apr 2013 14:40:27 -0400Subject: Re: Pietenpol-List: Re: Virginia Pietenpols
Subject: RE: Pietenpol-List: Thrust Pull 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________________________________________________________________________________Subject: Pietenpol-List: Re: Virginia Pietenpols
I=99ll be heading back to Virginia on Sunday after Brodhead.=C2- Will probably take two days to make the trip each way.=C2-I=99ll want to head to Brodhead on Tuesday, planning to arrive Wednesday.=C2- I try this every year and haven=99t gotten there before Friday yet.=C2-Jack PhillipsNX899JPSmith Mountain Lake, Virginia=C2-
I=99ll be heading back to Virginia on Sunday after Brodhead.=C2- Will probably take two days to make the trip each way.=C2-I=99ll want to head to Brodhead on Tuesday, planning to arrive Wednesday.=C2- I try this every year and haven=99t gotten there before Friday yet.=C2- Jack Phillips NX899JP Smith Mountain Lake, Virginia =C2-
Frank figured out the starting problem. I have 2 leads that were not firing atall, a really bad fouled plug (don't know which cyl), and the timing was off.Timing - that's easy. Bottom line - Frank says that the existing mags are reallyold and were at that time designed to be throw-aways - not repairable. So now I am in search of a set of mags for my O-200. Any one know of a set ofnew or used mags for sale? Meanwhile, Chuck loaned me a set of mags out of his Champ (its in rehab) so hecan bring Mr. Sam from PTB to Culpeper. With a little bit of luck, the Piet willbe in my hangar tonight and the journey from FL will finally be over.--------Jim McWhorterN687MB (New Owner)Culpeper, VA KCJRRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Virginia Pietenpols
I swear I posted this.... but can't find it.(1) Who is going to Brodhead this year?(2) Of those of you going to Brodhead - are any of you going to Oshkosh on SundayJuly 28th?(3) If you are not going to Oshkosh - are you planning on heading back to Virginiaon Saturday (27th) or Sunday (28th)?Me, I think I will have had enough camping for one trip - I will most likely beheaded back to VA at the end of Brodhead. I could be convinced to go to Oshkoshfor a day or two - but that would be the max.--------Jim McWhorterN687MB (New Owner)Culpeper, VA KCJRRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Re: air/oil separator
Sorry for the delayed reply, as I am nursing my 88 Year old Dad with abroken hip. I will try ASAP to get pictures and report our performance of the oilseparatorBarryNX973BP-----Original Message-----
Don wish mine was ready, maybe next year!Sent from my iPadJack TextorOn Apr 16, 2013, at 1:40 PM, "Don Emch" wrote:> > Just curious... Are any of you guys that are planning to fly their Piet to Brodhead,thinking about or planning to head to Oshkosh on Sunday morning. I'mhoping to fly my Piet to Brodhead then I am thinking very seriously about headingfurther north for a couple of days. Might be fun if we had a small group...> > Don Emch> NX899DE> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 744#398744> > > > > > > > > > ________________________________________________________________________________Date: Tue, 16 Apr 2013 20:30:54 -0400Subject: Re: Pietenpol-List: Re: Virginia Pietenpols
I'll be heading back to Virginia on Sunday after Brodhead. Will probablytake two days to make the trip each way.I'll want to head to Brodhead on Tuesday, planning to arrive Wednesday. Itry this every year and haven't gotten there before Friday yet.Jack PhillipsNX899JPSmith Mountain Lake, Virginia _____
This question posed by Dave didn't belong in a thread regarding flying to Brodhead,so I created a new thread.In response to your question, Dave...What??> n11dmx(at)yahoo.com> Guest> > Posted: Tue Apr 16, 2013 5:10 pm Post subject: Piets from Brodhead to Oshkosh? > > --------------------------------------------------------------------------------> > Sorry, but its a different subject.. > Just finished a mockup of my delevator system.. > All the pics of Petes show the elevators in the nose down position. > They are heavy, on balance fwd of hinge line. > has anyone put a spring in the system to offset the > heavy wood elevator > as is you must have to hold aft stick for level flight ? > Dave inverness, Fl > Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Virginia Pietenpols
Pietenpol-List: Re: "RE-PIET's" first kinda decent videos
Very nice Douwe!Rick SchreiberSent from my iPadOn Apr 17, 2013, at 3:23 PM, "Douwe Blumberg" wrote:> For those interested,> > Finally got two short videos that kinda show =9CRE-PIET=9D in action. > > Douwe> > http://youtu.be/mpkt0VlY1Ig> > http://youtu.be/RPoFpSn2A2I> > ============================================================================================================================================> ________________________________________________________________________________Subject: Pietenpol-List: Re: "RE-PIET's" first kinda decent videos
Re: Pietenpol-List: "RE-PIET's" first kinda decent videos
Original Posted By: Rick
For those interested,Finally got two short videos that kinda show "RE-PIET" in action. Douwe http://youtu.be/mpkt0VlY1Ig http://youtu.be/RPoFpSn2A2I____________ ... ___Subject: Re: Pietenpol-List: "RE-PIET's" first kinda decent videos
Hi Shad! Are you in Virginia?--------Jim McWhorterN687MB (New Owner)Culpeper, VA KCJRRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Virginia Pietenpols
Here's what I think I have figured out - Please chime in if I got it wrong.Going to Brodhead- Gene Rambo- Jack Phillips- Matt Paxton- Jim McWhorterOn The Fence- Marcus Zechini- Brett Phillips- ShadHaven't heard yet- Dave Boyd- Gary BoothReturning to VA on Sunday- Jack PhillipsGoing on to Oshkosh on Sunday---------Jim McWhorterN687MB (New Owner)Culpeper, VA KCJRRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Re: Virginia Pietenpols
Original Posted By: "M. Zeke Zechini"
You will not see me at B'head this year...sorry to miss all y'all!Gary BootheNX308MBSent from my iPhoneOn Apr 17, 2013, at 7:36 PM, "Fun2av8" wrote:> > Here's what I think I have figured out - Please chime in if I got it wrong.> > Going to Brodhead> - Gene Rambo> - Jack Phillips> - Matt Paxton> - Jim McWhorter> > On The Fence> - Marcus Zechini> - Brett Phillips> - Shad> > Haven't heard yet> - Dave Boyd> - Gary Booth> > Returning to VA on Sunday> - Jack Phillips> > Going on to Oshkosh on Sunday> -> > --------> Jim McWhorter> N687MB (New Owner)> Culpeper, VA KCJR> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 846#398846> > > > > > > > > > ________________________________________________________________________________
I think I am on the Brodhead side of the fence...Sent from my iPadOn Apr 17, 2013, at 10:48 PM, Gary Boothe wrote:> > You will not see me at B'head this year...sorry to miss all y'all!> > Gary Boothe> NX308MB> > Sent from my iPhone> > On Apr 17, 2013, at 7:36 PM, "Fun2av8" wrote:> >> >> Here's what I think I have figured out - Please chime in if I got it wrong.>> >> Going to Brodhead>> - Gene Rambo>> - Jack Phillips>> - Matt Paxton>> - Jim McWhorter>> >> On The Fence>> - Marcus Zechini>> - Brett Phillips>> - Shad>> >> Haven't heard yet>> - Dave Boyd>> - Gary Booth>> >> Returning to VA on Sunday>> - Jack Phillips>> >> Going on to Oshkosh on Sunday>> ->> >> -------->> Jim McWhorter>> N687MB (New Owner)>> Culpeper, VA KCJR>> >> >> >> >> Read this topic online here:>> >> http://forums.matronics.com/viewtopic.p ... 846#398846>> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________Subject: Re: Pietenpol-List: Re: Virginia Pietenpols
Original Posted By:> Jack Phillips
Shad...from where do you hail?Jack, take a look at 3VA7 on a chart. Rally point? Quite sure I am going. Sent from my iPadOn Apr 17, 2013, at 3:54 PM, shad bell wrote:> > I may be going this year, depending on what comes up. I have been trying to get my Baby Lakes finished so I can hopefully fly it this summer. If I have any money left for Brodhead Fuel I will go. I will probably head up on Thursday if I go.> > Shad> > --- On Tue, 4/16/13, Jack Phillips wrote:>
Even though not yet in Virginia (ETA late 2014) Dave Boyd is going to Brodhead in NX7710J.=C2- Departing CMI about '0 Dark Thirty'=C2-on Friday returning Sunday.On Wed, Apr 17, 2013 at 10:15 PM, M. Zeke Zechini wrote:Shad...from where do you hail?Jack, take a look at 3VA7 on a chart. Rally point?=C2-Quite sure I am going.=C2-Sent from my iPadOn Apr 17, 2013, at 3:54 PM, shad bell wrote:I may be going this year, depending on what comes up.=C2- I have been trying to get my Baby Lakes finished so I can hopefully fly it this summer.=C2- If I have any money left for Brodhead Fuel I will go. I will probably head up on Thursday if I go.=C2-Shad--- On Tue, 4/16/13, Jack Phillips wrote:
It's not that far...if you are One with the world...Gary BootheNX308MB-----Original Message-----
New to this experimental stuff .... where do I find the rules and regulations ofwhat I can and can't do to an experimental aircraft? I am positive they exist- I'm also equally sure they are somewhat restrictive. Just need to know whereto find them. I want to make sure my Piet is legal and safe.--------Jim McWhorterN687MB (New Owner)Culpeper, VA KCJRRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Virginia Pietenpols
Pietenpol-List: Re: FAA Rules & Regulations Regarding Experimental Aircraft
Wow, now that is a long XC. Sorry Gary, I got the impression you were a Virginiabased Piet. my bad! But, on the other hand - if you leave two weeks early- you can join us
--------Jim McWhorterN687MB (New Owner)Culpeper, VA KCJRRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: FAA Rules & Regulations Regarding Experimental Aircraft
Original Posted By: DandD Boyd
Tools,You are correct about changing the Limitations. That airplane has probably gotthe older type of Operating Limitations due to its age. If any changes are made,the local FSDO office WILL provide the plane with the updated version ofthe limitations. This is not necessarily a good thing. Do your homework beforejumping into doing this. I have been down this road in the past and electedto not change mine.My three cents,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Thu, 18 Apr 2013 11:17:07 -0500Subject: Re: Pietenpol-List: Re: Virginia Pietenpols
> ** Re: Pietenpol-List: Re: Virginia Pietenpols
Pietenpol-List: Re: going to Brodhead
Hey Douwe,I understand about life throwing curves at you! Who are the Louisville guys? Is one Jim Kinsella by any chance? As long as I don't get any curveballs eitherI'll probably be flying the route 30 corridor.Don EmchNX899DERead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
> > Hello everyone, my name is Mike Rich from the Dallas Tx. area. A little about me. I have researched for the past two years many different aircraft that would be a good build starting with a Piet,and ending with a Piet. I've been in model aviation for 25 years winning some scale contest and have been around full scale aviation since I was a boy with my father and brother. They kept nagging me,"When are you going to get your license and start flying for real" ? Well I finally did, but there's still something missing. I'm not building anything and it's driving me nuts!! So I joined the EAA,BPA ect. and was told this was the place to get advice if I want to build a Pietenpol Air Camper. Everyone in the Piet community has been very nice and down to earth...I love it. I feel I'm finally with the right group of aviators. I have thus far built a mockup from "Flying and Glider" to see how I would fit, bought all the Benglis books ect.So with that said, I need to order plans now. I'm 6'3" at 240 lbs. and I know I will need the longest fuse/ supplemental plans but I'm not sure about the rest. Do I order the whole shabang or just parts of it? Please advise,thanks.> > > > st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List> ttp://forums.matronics.com> =_blank>http://www.matronics.com/contribution> > > > href="http://www.matronics.com/Navigator?Piet ... enpol-List> href="http://forums.matronics.com">http://forums.matronics.com> href="http://www.matronics.com/contribution"> ... nics.com/c> > ============================================================================================================================================> ________________________________________________________________________________
> > I=99ll be heading back to Virginia on Sunday after Brodhead. Will probably take two days to make the trip each way.> > > > I=99ll want to head to Brodhead on Tuesday, planning to arrive Wednesday. I try this every year and haven=99t gotten there before Friday yet.> > > > Jack Phillips> > NX899JP> > Smith Mountain Lake, Virginia> > >
Original Posted By:> ** owner-pietenpol-list-server(at)matronics.com [
>> I=92ll be heading back to Virginia on Sunday after Brodhead. Will> probably take two days to make the trip each way.>>> I=92ll want to head to Brodhead on Tuesday, planning to arrive Wednesday. I> try this every year and haven=92t gotten there before Friday yet.>>> Jack Phillips>> NX899JP>> Smith Mountain Lake, Virginia>>> ------------------------------>
