Gene,The heat muff is 3" diameter exhaust pipe. It has two 1.5" holes drilled throughto slide up the two straight pipes and welded in place. The back side of themuff is closed off. A tube is welded into the side with a duct attached andrunning to the heat box. I heated and somewhat squared off the front of themuff to try to get about the same area of inlet as outlet. Let me know if youwould like more pics.DonRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Since the list has been quiet...
Pietenpol-List: Re: Since the list has been quiet...
At Brodhead Frank Pavliga and I had the chance to do some air to air work withAndrew King and Tim Loehrke. Tim took pictures while riding with Andrew in hisTaylorcraft. Here's a shot.DonRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Since the list has been quiet...
Sorry about no picture... how about this...Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/piet ... ___Subject: Pietenpol-List: Re: Since the list has been quiet...
One more... a little more comfortable for this one. Frank was made me nervousa few times there!DonRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/piet ... __________
RE: Pietenpol-List: Re: Since the list has been quiet...
Subject: Re: Pietenpol-List: A 65 exhaustGene,There is no such thing as "beyond repair" for those exhaust repair guys. Call Dawley's in Wisconsin. They advertise in Trade a Plane all the time andI recommend them. Dan HelsperPoplar Grove, IL.________________________________________________________________________________Subject: RE: Pietenpol-List: Re: Since the list has been quiet...Date: Thu, 27 Sep 2007 07:10:15 -0400
Subject: Pietenpol-List: Cockpit doorGardiner: I would atleast put some ply gussets at every intersection ofthe braces, longorons etc. Leon S. ________________________________________________________________________________Subject: Pietenpol-List: Re: Since the list has been quiet...
